2010 Prius Caught Fire
Discussion in 'Gen 3 Prius Main Forum' started by savany71, Nov 20, 2014.
  1. 2k1Toaster
    6,035
    3,855
    Rocky Mountains
    Unfortunate and glad everyone is OK. But car fires do just happen some times. That's what insurance is for.
  2. wjtracy
    wjtracy Senior Member
    11,370
    3,608
    Northern VA (NoVA)
    ^^^I had a buddy burn down his house decades ago but he had the car (non hybrid) running to warm up. So there I can see the pumping of fuel in.
  3. savany71
    savany71 Junior Member
    Seattle
    Insurances are with different companies. Having to deal with both separately is a real pain.
  4. Steve terry
    Steve terry Member
    217
    Oklahoma
    I was a fire Captain and I can tell you, the fire dept. will not fill a report with anybody like you think. They do a fire report and most of the information inputted will be used in a national data base to count different types of things like CAR fires, outdoor fires, house fires. It is very hard to determine what started a car fire. One not so common cause in the cabin is having a cell phone charging with a non standard cord or battery. But you said the engine compartment was burning when you came out. I hope you had good insurance on it.
    Sorry for your loss.
    walter Lee likes this.
  5. Mendel Leisk
    41,901
    You'd think Toyota would want to send someone over to have a look.
  6. yeldogt
    yeldogt Active Member
    810
    313
    NE
    Not the best picture .. this is mine. It happened over two years ago and I just settled the house claim. Cars were only a couple of weeks.
  7. bisco
    52,390
    prius? cause?
  8. Former Member 68813
    3,524
    983
    US
    Yeah, right! Don't expect they'll just call you and say sorry. They'll lawyer up.
    Here is where you go: File a Vehicle Safety Complaint Form | Safercar.gov | NHTSA
    You can also ask NHTSA to look specifically into prius fires.
    However, judging from the pictures/video the engine and not the hybrid part was the fire source. I guess AC is a possibility too.
    walter Lee and cwerdna like this.
  9. xliderider
    xliderider Senior Member
    8,140
    3,277
    Honolulu, HI
    Have you made any enemies lately? :eek:
    Seriously, glad no one was hurt and that your house is still relatively intact.
    SCH-I535
  10. David Beale
    David Beale Senior Member
    5,963
    1,989
    Edmonton Alberta
    It was probably a coolant fire. It's on that side, coolant pumps etc. Just takes one plastic spigot to fail and coolant is dumped on the exhaust, where it will ignite. There isn't enough fuel under the hood to support a fire though there is enough to be an ignition source, but the lines etc. are carefully engineered to prevent that.
    I had a 3rd gen RX-7 that had been rebuilt after a coolant fire ignited by the turbos. It was recall based, but the owner hadn't taken it in yet.
    How long did it sit after shutdown before you noticed the fire?
  11. xliderider
    8,140
    3,277
    Honolulu, HI
    The coolant fire angle is interesting. I found this:
    AUTOMOBILE ENGINE COOLANT RELATED FIRES
    OP, was any work done on the cooling system at the 90k service? In the article, the radiator cap wasn't properly placed on the radiator, which allowed the water to possibly boil off, leaving a much more concentrated glycol mixture, which is much more flammable when expelled onto a hot ignition source.
    walter Lee and Silver bullit like this.
  12. ETC(SS)
    7,355
    Hmmmm...
    Service (90K) done in May.
    Fire in late November.
    Technically the dealer might be the cause, but you'd have a hard time selling ME on that idea and I have a pretty anti-stealer bias.
    Besides....if the dealer did do something like leave a coolant cap off or knock a fuel line lose then I would expect that it would generate a code or the customer would---SHOULD peek under the hood every now and then to see if the hamsters under the hood are still running on the wheel.
    Speaking of which - there might have been some critters in the air-box fluffing up their nests for Winter.
    It could be vandalism....
    Arson.....
    A manufacturer defect......
    Aliens....
    Elvis...
    OR......
    OR.....
    A fifteen year old kid that doesn't want to be bullied for driving a Prius! :eek:
    Even in Seattle.....
    If it was a manufacturer defect then it's a pretty isolated incident.
    This is one of the very few Prius fires that I've seen that wasn't caused by an obvious external source.
    Get a check from the Insurance Companies.
    Give the kid some rudder input on your/his next car.
    Give thanks that it's just stuff and nobody got hurt.
    Good Luck!
  13. miscrms
    miscrms Plug Envious Member
    2,079
    527
    Phoenix, AZ
    Yeah, the AC compressor is on that side and is run of the HV battery. But as long as the car was powered off (ie not left in "ready' mode") there is no high voltage present anywhere but inside the battery box in the back. I believe the 12V is still energized up as far as the fuse box, but that's on the driver side top.
    Given the time of year and location of damage, I'd certainly lean toward flammable fluid leak on hot exhaust manifold and/or rodents nesting and nibbling?
    Rob
  14. retired4999
    2,652
    627
    Eau Claire, Wi.
    Mice can be a big problem? Chewing and nests!
    Wishing you the best! Good luck!!!!
  15. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,801
    Undisclosed Location
    Hmm...
    That's obviously too bad, but on the positive side, you only lost a vehicle, not a house or a life.
    The way I look at it, The Prius is also obviously not designed to spontaneously combust. And I don't read a lot of threads where this is happening. Once...for any owner is once too many...but I don't think it is a common occurrence.
    I'd be curious as to the ultimate conclusion, if any specific cause can be determined.
    I think many of the theories proposed are possible and viable. Which one might be right? I have no idea.
    I think Hybrids are great. But the truth is they do have a high voltage battery and wiring. Does this increase the chance that numerous potential scenarios could develop or happen that "might" lead to combustion?
    Well, I am curious as to what is found out. Any melted rodents included in the aftermath?
  16. Den
    Den Junior Member
    30
    SF Bay Area
    There nothing in engine compartment that can burn so long and hot, no power steering oil’s/ fluids, no rubber belts or batteries. Well, maybe few oz of gas in gas lines. Are you sure you have no enemies or "friendly" neighbors?
    #56 Den, Nov 21, 2014
  17. savany71
    Seattle
    Just a quick update, fire investigator which was hired by my homeowner insurance came out and took bunch of photos but didn't say much on how & what. They have given the ok to tow the vehicle away by my auto insurance company. Since it is Friday, they said it might be on Monday at the earliest to tow it away. Homeowner insurance company requested that car to be owned, wrapped and preserve it. Toyota stated that someone will be in contact me within 24 business hours but no contact from them. I took 3 days off work to deal with fire restoration company, contractors, insurance company reps. I just want quick resolution so I can move on.
    Insurance company declared total loss on this and I'm waiting on that department to call to discuss the value. I'm just hoping they value the car fair so I can buy similar vehicle for my son.
    Since you mention it, I'm sure I can probably think of a few!?!?!?!
    #57 savany71, Nov 21, 2014
  18. bisco
    52,390
    probably a hummer driver?
  19. savany71
    Seattle
    It can be any number of things as you said, I'd love to find out what happened and the cause, fire investigator, who was hired my homeowner's insurance company was out today so maybe he can shed some light on this.
  20. yeldogt
    810
    313
    NE
    Homeowners wants to preserve any evidence in case they can make a third party claim .. Unlikely. Did you get much smoke damage?
    I had agreed value on my cars .. so very good outcome with that part of the loss.
