2006 Factory Foglights.
Discussion in 'Gen 2 Prius Main Forum' started by roocow, Apr 2, 2006.
  1. roocow
    roocow New Member
    Any info out there on a FACTORY foglight kit?
  2. V8Cobrakid
    V8Cobrakid Green Handyman
    3,790
    152
    Are you looking to upgrade to a fog kit since you have a base prius?
    I wouldn't consider them fogs really. My HIDs work better, and they really didn't help in snowy conditions either.
  3. roocow
    roocow New Member
    I am looking to get rid of the ugly grill ends...and go with the factory foglights
  4. V8Cobrakid
    3,790
    152
    have you checked ebay?
  5. roocow
    roocow New Member
    I have checked Ebay...and all over the web..
  6. V8Cobrakid
    3,790
    152
    hmm. I haven't seen any sorces since i joined. I read almost every forum created. Unfortunetly at this time of night, the forums are not too active. keep bumping your topic and you'll be sure to get a response sooner or later.
  7. KTPhil
    KTPhil Active Member
    1,379
    22
    Factory fogs are useless. The HIDs outshine them, and have a good top cut-off, making them fine in fog as-is. You might look for some high intensity foglamps that could be mad eto fit your stock grilles after cutting out and perhaps reinforcing them. Then use the usual relay/fuse protections.
  8. darelldd
    6,059
    389
    Northern CA
    <div class='quotetop'>QUOTE(KTPhil @ Apr 3 2006, 11:20 AM) [snapback]234226[/snapback]</div>
    Only with the stock bulbs! Just add a 9006 HID kit to the factory, and I hear they're instantly useful. That's my plan... stay tuned.
  9. jdjeep98
    jdjeep98 New Member
    211
    Wilmington, DE
    <div class='quotetop'>QUOTE(darelldd @ Apr 3 2006, 02:25 PM) [snapback]234228[/snapback]</div>
    Hmmm... :) sounds interesting... More info? :D
  10. DocVijay
    DocVijay Active Member
    1,455
    Tampa, FL
    <div class='quotetop'>QUOTE(jdjeep98 @ Apr 3 2006, 05:11 PM) [snapback]234304[/snapback]</div>
    Check my thread in my signature. I've done the HID Conversion to my fogs.
  11. darelldd
    6,059
    389
    Northern CA
    <div class='quotetop'>QUOTE(jdjeep98 @ Apr 3 2006, 02:11 PM) [snapback]234304[/snapback]</div>
    Like Bjorn says - he's already done it... and that has inspired me. You just need a 9006 HID conversion kit (many brands and tints to choose from) and you're on your way. I recommend that you don't go above 6000k for color temp, unless you really like reduced output, and purple lights.
  12. Tideland Prius
    16,597
    4300K okay?
    I saw DocVijay's installation. Still unsure if it's the kind that I can do. I mean, I can do Coastal's EV mod but not the OEM one.
  13. DocVijay
    1,455
    Tampa, FL
    <div class='quotetop'>QUOTE(Tideland Prius @ Apr 3 2006, 06:20 PM) [snapback]234348[/snapback]</div>
    The 4300k is fine if you want to match the factory HID's. That's why I went with that temperature.
  14. darelldd
    6,059
    389
    Northern CA
    <div class='quotetop'>QUOTE(Tideland Prius @ Apr 3 2006, 03:20 PM) [snapback]234348[/snapback]</div>
    Not much to it. The first part is like changing the bulb (you have to remove a couple of bolts on the belly pan and pull the plastic down, then reach in a twist the bulb out, and the new HID in). The harder part is finding a place to strap the balast. I think you can do it if you managed the Coastal mod. The OEM version of the EV mod isn't much different, BTW! Just a few more panels to remove.
  15. BobZ
    BobZ New Member
    323
    Long Island, NY
    <div class='quotetop'>QUOTE(roocow @ Apr 2 2006, 11:39 PM) [snapback]234010[/snapback]</div>
    Here is the original Toyota part number for the fog lights 81211-52070 times two. Left and right are the same part number. The grilles that surround them are 53112-47030 and 53113-47030 (left and right) The bulbs are standard 9006 bulbs that can be found in ANY auto parts store. The wiring I got on ebay. Here is what I used...
    http://cgi.ebay.com/ebaymotors/01-03-TOYOT...008636179QQrdZ1
    The kit had the correct plugs for the bulbs. It had a relay even a switch. A simple positive and negative connection. No big deal. From the outside they look stock because they are.
    The original grilles pop right out. Gently pull them out. The lamps literally snap in. The bumper is molded for them even on the non fog light cars. The new grilles also snap right in. It couldn't be easier.
