CVT ATF level check
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by Tony Lees, Nov 23, 2014.
  1. Tony Lees
    Tony Lees Junior Member
    My 2012 Prius C contains 3.5 qts of Auto Trans Fluid. I have been unable to find a dip stick to check the level. Does anyone know for sure how to check this level?
  2. Mendel Leisk
    41,865
    The official method is remove the tansaxle fill bolt and with the car level: feel with a finger, if it's level with the bottom of opening, or less than 10 mm lower *, it's good.
    In practice, if there's no leakage, I'd leave it alone.
    It's worthwhile to change, say every 30000 miles. The fluid to use is toyota ATF-WS.
    * that 10 mm number might vary, might be 5, might be 10.
  3. Tony Lees
    Thanks Mendel. Guess it's not planned to be user friendly unless you have a lift, pit or real thin body.
  4. KYBlue
    KYBlue Active Member
    227
    112
    If you have some ramps you can check it easily. I did the ATF fluid change at 30k with ramps and hand tools.
    Chris
    kevtan likes this.
  5. Andyprius1
    Andyprius1 Senior Member
    2,327
    859
    Cool CA
    . It's actually easy, but like everything , a project.
  6. Mendel Leisk
    41,865
    Neglected to mention, the car should be level when you check. I've changed the fluid a couple of times, but never check the level in between changes: just too much hassle. If you're not seeing leakage it's fine.
  7. Matt H
    Matt H Active Member
    164
    105
    Okinawa Japan
    2012 Aqua
    In short, if it's not leaking, where did it go? Answer: It didn't go anywhere.
    Engine oil can "disappear" because it gets burned in combustion, either by getting past the rings, or through the PCV system. If there are no leaks, there is no reason to check the transaxle oil, because it's all still in there ;-)
