DEAD BATTERY - LEFT SITTING SINCE JAN 2014 HELP!!
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by jay mcmullan184, Nov 29, 2014.
  1. jay mcmullan184
    jay mcmullan184 Junior Member
    Virginia
    Was deployed to Afghanistan and left my car in the driveway (soon to be EX doesn't have DL) and I tried starting it yesterday. According to my soon to be final divorce decree I am giving her the car so I don't want to spend much $$ to get this car up and running.
    What can I do? Replace the 12V battery? What are the odds the "BIG" battery is bad too? Will it run with just the 12V ? It is a 2007 with Opt package #4 and has about 168k miles on it. Was thinking about trying to charge the battery but think it might be a waste of time... with no experience here I'm lost !! It's been an awesome car with only A/C problems and after 4 times to dealership Toyota replaced the ENTIRE system...no problems since. Thanks
    51,879
    it's most likely the 12v. it's hard to say on the big battery because you need to fire up the computers to find out. is the 12v original? if so, just replace it. grab one at toyota or auto zone or somewhere, they are easy to change. make sure it reads 13v before installing or it might need a charge.
    #2 bisco, Nov 29, 2014
  3. css28
    css28 Senior Member
    1,566
    443
    Suburban Detroit
    Most likely it's just the 12V battery that's dead.
    It's also likely that the 12V won't hold a charge after sitting flat like that.
    The car will act strange with a failing 12V battery but carefully boosting the 12V from another vehicle can help you determine if the big battery is healthy enough to start the car.
  4. fotomoto
    fotomoto Senior Member
    5,634
    3,812
    So. Texas
    Remove the 12v and take it to an auto parts store that can do a free "load test" on it. This will tell you if it needs replacing or simply recharging. Most likely needs replacing.
  5. valde3
    valde3 Senior Member
    2,002
    749
    Finland
    If big battery doesn’t have enough charge to start engine it’s probably enough just to slowly charge it with grid charger.
  6. Mendel Leisk
    41,381
    Our 2010 has a build date of August 2009, and we bought it, with maybe 6 km's on the odometer, in November 2010. The 12 volt was toast, the dealership conceded it*, put in a fresh one. But the hybrid battery has been just fine, nothing untowards, to date.
    * The dealership first tried every trick under the sun to dodge 12 volt replacement, it was pretty pathetic. When we first showed up to test drive it, they had it in ready mode, basically on. I'm sure they'd been jump starting it behind the scenes. After the drive we went back in, then in the discussion, something came up that required going back out and starting the car again...
  7. flxcon
    flxcon Junior Member
    los angeles
  8. flxcon
    los angeles
    I will help you to fix it. If you live in los Angeles. 3233502278. I am getting divorced and I know what it is. I won't charge you.
