2013 Headlights
Discussion in 'Gen 3 Prius Accessories and Modifications' started by fielou, Nov 28, 2014.
  1. fielou
    fielou New Member
    NY, NY
    Headlights on 2013 Prius too dim. Anyone know of good aftermarket headlight assembly for 2013 Prius with stronger bulbs. Have tried HID bulbs, not much improvement. Have seen this issue mentioned elsewhere.
  2. F8L
    19,011
    4,083
    Grass Valley, CA.
    There are none.
    You will either have to do an HID retrofit (DIY or send them In for custom work) or install Prius Five LED headlight assemblies.
  3. xliderider
    xliderider Senior Member
    8,131
    3,268
    Honolulu, HI
    OP, HID lights too dim? Maybe you need to make an appointment with an optometrist/ophthalmologist?
    SCH-I535
  4. A.Reyes
    A.Reyes Active Member
    270
    178
    Beaufort, 29902
    #4 A.Reyes, Nov 29, 2014
  5. prius621
    prius621 New Member
    NC-San Francisco Branch
    Not sure which HID kit you bought, but my 55w 5000k is very bright.
  6. xliderider
    8,131
    3,268
    Honolulu, HI
    OP must be looking for something like this:
    The light on the truck would put out more than a million candela.
    #6 xliderider, Nov 29, 2014
  7. Leslie Trew
    Leslie Trew Junior Member
    Hello. Are you saying that you just need to install a bulb, and not install this entire kit? I need the low beams to be brighter and extend longer from the car.
  8. xliderider
    8,131
    3,268
    Honolulu, HI
    You would need to have the 55w ballasts as well, bulbs + ballasts. A relay is also a good idea for a 55w kit, the ballasts can draw much more power than 55w when igniting the HIDs.
  9. prius621
    prius621 New Member
    Like xliderider said, you need the entire kit; which includes bulbs and ballast. Just to be on the safe side, I went ahead and installed a relay as well even though I didn't experience any "flickering".
  10. Sfcyclist
    Sfcyclist Senior Member
    1,621
    375
    SF, CA
    Reading between the line here but I think what you tried are Xenon halogen bulbs NOT HID kit. I've own and owned a lot of cars with factory HID's and my conversion in terms of brightness, is right in line with those. I even posted a comparison which I will try and dig up.
    Get a 35watt HID digital kit, and lack of lumens will not be an issue.
    #10 Sfcyclist, Dec 16, 2014
  11. Robert Bo
    Robert Bo Junior Member
    Seattle, WA
    2013 Prius v wagon
    Ok guys I finished the install and the lights don't work. Is there any actual instructions somewhere?
  12. xliderider
    8,131
    3,268
    Honolulu, HI
    Robert, same answer as the other thread you posted in. Try turning the oem plug around 180 degrees, and reconnect to your HID ballast. It sounds like the polarity is reversed.
  13. Robert Bo
    Seattle, WA
    2013 Prius v wagon
    Thanks all it was in fact reversed-fired right up -:)
