Need pinout for overhead dome light Gen 3
Discussion in 'Gen 3 Prius Accessories and Modifications' started by teamneon, Nov 25, 2014.
  1. teamneon
    teamneon Junior Member
    Western KY
    Hi guys, im working on a mod but need to know if anyone has a pinout for voltage for the gen 3 overhead light panel? Here is the panel. It has a 20pin plug in.
  2. kenmce
    kenmce High Voltage Member
    1,551
    523
    NY
    Does this car have that Toyota OnStar thing?
  3. teamneon
    Western KY
    No it does not. I traced it out. ill post what im doing tonight. thanks
  4. 4o66
    4o66 Junior Member
    Southern California
    2019 Prius Prime
    Ok, working on adding an aftermarket HomeLink door opener and needed this info too.
    Here is what I found: (2015 Prius Persona, no OnStar-like service.)
    Pin 1: White/Black Ground
    Pin 2: Black Mic:SNS2
    Pin 3: White Mic:MCO-
    Pin 4: Black Mic:MCO+
    Pin 5: Red Mic:MACC
    Pin 6: Purple, N/C to Board
    Pin 7: Green, N/C to Board
    Pin 8: Green Tail lights on (+12v)
    Pin 9: N/C
    Pin 10: Yellow, N/C to Board
    Pin 11: Doors Open (Pulls to Ground on Door Open)
    Pin 12: White Rear dome light Door Open (Pulls ground if switch in in "Door" mode and Doors are open.)
    Pin 13: N/C
    Pin 14: N/C
    Pin 15: N/C
    Pin 16: N/C
    Pin 17: White Ground out to Rear Dome
    Pin 18: N/C
    Pin 19: White +12v out to Rear Dome
    Pin 20: Red +12v (10A Fused, Dome Light)
    N/C = Not Connected.
    Some pins had wires on the plug, but were not connected to anything on the dome light circuit board.
    Pins 2-5 are for the Blue-tooth microphone.
  5. mrbigh
    3,686
    699
    Long Island, NY
    THANKS FOR THE INFORMATION
