best 215 45 17 tyres for fuel economy????
Discussion in 'Gen 3 Prius Main Forum' started by graham hendren, Dec 4, 2014.
  1. graham hendren
    graham hendren Geeman .. taximan
    82
    NOTTINGHAM ENGLAND. UNITED KINGDOM
    2014-12-04 14.14.18.jpg 2014-12-04 14.13.10.jpg 2014-12-04 14.13.10.jpg 2014-12-04 14.13.10.jpg 2014-12-04 14.13.10.jpg these are the best fuel save tyres I have found b rating for fuel and b rating for wet and there are around £80 uk pounds each
    F8L likes this.
  2. graham hendren
    82
    make sure you get xl 91w as there are 2 types and the others are not as good.
  3. F8L
    19,011
    4,083
    Grass Valley, CA.
    Are there better options if you go to a 205/50/17?
  4. graham hendren
    82
    not sure im on the 17 " wheels and the right tyre is a 215 45 17. and these are the best I have found even better then the standard Michelin's . they just roll better sound better make the car easy to drive less hard acceleration needed hence better fuel economy
  5. Blizzard_Persona
    1,787
    946
    Pa.
    2023 Prius Prime
    XSE
    Looks like a winner!
    Alas not avail in USA right...? :(
  6. F8L
    19,011
    4,083
    Grass Valley, CA.
    A 205/50/17 is also the right tire if you want a slightly taller sidewall, which better matches the size the of 195/65/15. The 215/45/17 is actually a shorter tire than the 195/65/15. It's an optional size that some of us choose. :)
    Still, a B rating is pretty good in this size.
  7. Mendel Leisk
    40,687
    One sticking point with 205/50R17 might be convincing a shop to do them. In Canada/USA Costco for one can be royal pains, doing anything other than stock, both for tires sizes and the psi of that precious nitrogen they'll put in. I'm still thinking about it tho, thanks to F8L's suggestion.
  8. prifahrer
    prifahrer Junior Member
    225/45/17 will also provide more choice (i got dunlop blueresponse, happy with them, but my initial set on the car, so cannot compare...) about the same total diameter as 195/65/15.
