EV Mile Tracker
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by bisco, Jun 3, 2013.
  1. bisco
    52,295
    17,500.:giggle:
    Potorap and JBumps like this.
  2. retired4999
    2,652
    627
    Eau Claire, Wi.
    You go!! :)
  3. Potorap
    Potorap Active Member
    345
    148
    Pahrump, Nv
    Awesome!!!!!!!!!!
  4. jack520
    jack520 Member
    154
    40
    2014 Prius Plug-in
    I have 2500 EV miles, but what the heck, my car is only 4 months old.
    fortytwok and bisco like this.
  5. retired4999
    2,652
    627
    Eau Claire, Wi.
    You must be charging twice a day every day way to go!:)
    Great job!
  6. bisco
    52,295
    looks like my time here is limited.(n)
  7. CraigCSJ
    CraigCSJ Active Member
    287
    144
    San Bernardino, CA
    My car says it has gone 15137 miles on 2705 KWh. I applied a .15% loss, and calculated MPGe at 163.99 which seems high. Did I calculate wrong? (15137 divided by (1.15* 2705 divided by 33.7))
  8. retired4999
    2,652
    627
    Eau Claire, Wi.
    If 15137 miles is all ev miles only, yes, gas equivalent MPGe. You are correct.
  9. CraigCSJ
    287
    144
    San Bernardino, CA
    Those figures come from the left side of the EV Driving Ratio screen on the dash. On the right it has 22248 miles and 435 gal. Which I believe is HV. My record of gas from the pump is 453.396. I wonder which gasoline reading is more correct. The miles numbers total the total miles driven on the odometer.
    retired4999 likes this.
  10. retired4999
    2,652
    627
    Eau Claire, Wi.
    Your doing a great job!! (y)
    Enjoy!:D
  11. jack520
    jack520 Member
    154
    40
    2014 Prius Plug-in
    That is what I do ! Once at home before work then at work every day !
    However I do drive a lot and I am at only 18% EV...
    Jack
  12. bisco
    52,295
    the pump numbers are correct. the car only records full gallons.
    CraigCSJ likes this.
  13. bisco
    52,295
    18,000!!!
  14. rxlawdude
    rxlawdude Active Member
    701
    220
    So Calif
    2015 Tesla Model S
    More correctly, the car reports a truncated, integer-only gallon figure. Not rounded. Truncated. (0.99999999 gallons displays as "0.")
  15. bisco
    52,295
    thank you your honor, the prosecution rests.
  16. rxlawdude
    701
    220
    So Calif
    2015 Tesla Model S
    Sorry, pedanticism runs deep in professors. :D
  17. bisco
    52,295
  18. Godzuki
    Godzuki Active Member
    133
    114
    Bay Area, CA
    2015 Prius Plug-in
    EV 16,592 (21%)
    HV 61,234 (79%)
    I recently fitted the PIP with 17 in rims - my mileage went down, but my smile-age went up as I love the looks! ;)(y)
    Lifetime mpg is 69. Daily commute is 70 miles round trip. I charge twice a day M-F - once at home in the morning and again at work in the afternoon. I generally only have an opportunity to charge once on the weekends...
  19. bisco
    52,295
    that looks sweet. you put in some serious windshield time!:cool:
    Godzuki likes this.
  20. markabele
    5,084
    1,782
    Nebraska
    I'm to about 13,300 EV miles now. :)
