Oil Discoloration
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by briansgreencar, Dec 8, 2014.
  1. briansgreencar
    briansgreencar Junior Member
    Delmar, NY
    I recently took my car in to the dealership for a 50,000 mile oil change. 2 days later I checked my dipstick and the end showed a very discolored oil (rust colored) which had a lot of sediment in it.
    I have since taken it back to the dealership and they don't seem to know what the problem is. They have since changed the oil again and it still has a rust color to it.
    Has anyone experienced this before?
  2. JC91006
    JC91006 Senior Member
    16,925
    8,636
    That could be the color of the oil they use
  3. briansgreencar
    Delmar, NY
    Oil color and rust like substance were different. Dealership is saying they have never heard of this issue.
  4. JC91006
    16,925
    8,636
    How long did you go before your last oil change?
  5. briansgreencar
    Delmar, NY
    Oil changes have been regularly done(according to the owners manual at 5k, 10k, 20k, 30k, 40k & 50k
  6. fotomoto
    fotomoto Senior Member
    5,639
    3,815
    So. Texas
    Orange color coolant mixing with it?
  7. briansgreencar
    Delmar, NY
    rust colored orange. No foam.
  8. frodoz737
    frodoz737 Top Wrench
    4,784
    2,549
    33
    HD pictures please.
  9. briansgreencar
    Delmar, NY
    Not the best quality-but it shows the rust color Mixing with fresh oil
  10. JC91006
    16,925
    8,636
    when the dealer saw it, what did they tell you?
  11. frodoz737
    4,784
    2,549
    33
    Using only the info you have provided...this needs to be addresses asap to make sure.
  12. briansgreencar
    Delmar, NY
    To make sure of what? The dealership has no idea what it is. They have started a technical assistance case.
    I believe there resolve is that they changed the oil enough times that the rusty color is gone.
    I'm not sure what else I can do. Other than a corporate complaint.
  13. frodoz737
    4,784
    2,549
    33
    Drain and retain your current oil and try using an oil analysis if your case is going nowhere. Blackstone Labs
  14. phoenixgreg
    phoenixgreg Senior member
    1,157
    295
    66
    Phoenix
    Try to notice if your engine is "making oil" too. My guess is you have a coolant leak into the oil system. The pink coolant might just turn orange once combined with hot engine oil. As frodoz737 says, get a free kit from Blackstone labs. Then get it analyzed ($25 according to the website). If it is coolant, you have a bad problem.
    #14 phoenixgreg, Dec 8, 2014
  15. frodoz737
    4,784
    2,549
    33
    Know it's not my place to tell you what to do, but do it now. Anything "not oil" here is very bad.
  16. briansgreencar
    Delmar, NY
    Thanks. So far the local dealership is saying they have never seen anything like this. I will keep you posted
  17. Former Member 68813
    3,524
    983
    US
    Horrible quality. Perhaps you know someone who has semi-decent cell phone or camera?
  18. Easy Rider 2
    Easy Rider 2 Senior Member
    1,584
    258
    Ocala, FL
    There are several things that the "mechanics" can do.....like pressure test the cooling system and look for oil floating on the top of the coolant.
    That sure looks like water is getting into the crankcase.
    This time of year, that can also be caused by a fault in the Positive Crankcase Ventilation (PVC) system, allowing water to condense out of the air when the engine is first started cold.
    Do you use your car for a lot of short trips when the engine cools down between them ?
    In rare cases, that can be "normal" and indicates a need for a longer engine run once a week or so.
  19. briansgreencar
    Delmar, NY
    The majority of trips are short (under 20 minutes), but it is used for longer trips every 2 or 3 days.
  20. frodoz737
    4,784
    2,549
    33
    While the photos and description do "appear" to be a water based substance, take it back and let the "mechanics" do their job to find out what it is for sure. Having the same results after another "oil-flush" would indicate the problem is real. When a Service Adviser or the runner up for Service Manager says I don't know...that usually means nothing except they want you to pay for their time. Escalate the process before more "possible harm" might be done to your engine.
