Found a disconnected plug, not sure what it is
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Johnny KIlo, Nov 29, 2014.
  1. Johnny KIlo
    Johnny KIlo Junior Member
    51
    Chicago suburbs
    Found this near the front passenger headlight. Any idea what it is
    52,242
    block heater?
  3. Johnny KIlo
    51
    Chicago suburbs
    Not sure, I believe the previous owner put in aftermarket HIDs so that might be the factory harness assuming it is hard wired, I cant quite tell. THe block heater only heats the engine right? I ask because I am not getting any hot air in the cabin.
  4. bisco
    52,242
    yes, if you plug it in, it keeps the block warm so when you start it, it's somewhere above ambient temp.
  5. bisco
    52,242
    no heat in the cabin could be damper control, cabin radiator, thermostat, coolant control valve? are there any codes?
  6. Johnny KIlo
    51
    Chicago suburbs
    No codes. I suspect air in the coolant system, gonna bleed it tonight.
  7. bisco
    52,242
    good thought.
  8. Johnny KIlo
    51
    Chicago suburbs
    Heat was definitely the result of low coolant. It took nearly an entire gallon.
  9. bisco
    52,242
    yikes! is there a leak?
  10. Patrick Wong
    18,210
    6,511
    Look at the engine coolant pump. You'll probably see a pinkish stain at the pump bearing, you may see residue deposited on the air conditioner compressor.
    If you see this, you need to replace the engine coolant pump now. If the engine coolant really was almost one gallon low, that probably caused permanent damage to the engine depending upon how long this condition persisted.
    The Prius engine coolant capacity is ~9 US quarts of which three quarts are for the coolant heat recovery system. Thus, around six quarts are circulating in the engine and cabin heater core. If you were four quarts low then you only had two quarts circulating around, which would result in the engine head overheating and potentially warping due to lack of coolant. This would lead to low cylinder compression, mixing of engine coolant and engine oil, poor performance, bad mpg, etc.
    Check the engine oil to see if it is contaminated with coolant. Check the coolant to see if it is contaminated with oil. If you see either, time to start looking for a replacement engine.
  11. TampaPrius.com
    TampaPrius.com Active Member
    461
    300
    Tampa, Florida
    I have replaced two engines that had overheated and had warped heads. Neither one showed oil in coolant or coolant in oil. When they would get warm the coolant hoses would become hard as a rock and coolant eventually blows out through overflow tank.
  12. Johnny KIlo
    51
    Chicago suburbs
    yeah, I replaced the thermostat and the water pump and the gaskets were past their prime.
  13. bisco
    52,242
    ah, good outcome!(y)
  14. Johnny KIlo
    51
    Chicago suburbs
    Thanks Patrick, I'm gonna check it today. When I replaced the water pump and thermostat I didn't notice and oil in the coolant. Ill check the oil for coolant as well.
  15. bisco
    52,242
    ever figure out the plug?
  16. Johnny KIlo
    51
    Chicago suburbs
    haha, no I didn't. It's a little further down my list right now. I'll post once I get to it
