Who Else Has Switched to Premium Fuel 92 OCTANE?
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by Prius Five Guy, Dec 13, 2014.
  1. Prius Five Guy
    170
    Los Angeles
    2013 Prius Plug-in
    Apparently the cleaner burning fuel makes me look more handsome? Seriously folks, who else is filling up with higher grade fuel with the recent drop in prices?
    Apparently 92 octane is burns "cleaner" whatever that may mean...
    Thoughts?
  2. orenji
    orenji Senior Member
    5,887
    3,488
    I have been since day one regardless of price.....
  3. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
    "Premium" does nothing for a Gen 1, Gen 2, or Gen3 Prius, Prius PHV, or v. Some drivers feel that it does something for the c, I do not own a c and can't confirm or deny that.
    Since 1995, 'premium' is no 'cleaner' than 'regular' in the US.
    http://en.wikipedia.org/wiki/Top_Tier_Detergent_Gasoline#History
    You, of course, may continue to use Premium, you are only wasting money.
    (In some locations, premium is E0 while regular is E10, also some locations do not use reformulated gasoline as premium but to so for regular. California is not any of those places)
  4. Blizzard_Persona
    1,787
    948
    Pa.
    2023 Prius Prime
    XSE
    Premium is only required as deemed by the mfgr. Aka not in the prius at all, waste of money..
    It is needed in high compression engines especially EDIT: "most" turbo engines that require the slower burn of the fuel. Yes that seems counterintuitive but high test burns slower.. Go figure.
    Engineers out there edit as needed, although after owning a few turbo'd veh's that required premium fuel I read up on the topic and what I posted seems to be the consensus...
    Edit = cruze ECO was a small turbo that didn't require premium but in my experience had better throttle response while running premium. My above statements were in reference to high performance turbo'd engines....
  5. Mendel Leisk
    41,915
    Appearances aside, all higher octane does is resist ignition better. It's tailored for higher compression engines, the ones prone to pre-ignition.
    Not exactly exciting, eh? ;)
    KennyGS and Epiphany2000 like this.
  6. bisco
    52,396
    after seeing my 3 pri go over a total of 240,000 miles on regular, with no detrimental effects, i can't see any reason to.
  7. GregP507
    GregP507 Senior Member
    3,002
    481
    Using Premium in a car that doesn't require it is dumb. There's absolutely no evidence that it's better than Regular in a vehicle that's designed for Regular.
    kenoarto and dbcassidy like this.
  8. Tideland Prius
    16,621
    Anything higher than 87 octane isn't usually worth it, although @bwilson4web did mention somewhere that 89 octane can help on road trips (high load instanances? Hopefully he can clarify).
    I wonder if there's any benefit with 89 or 91 IF they are E0 fuels? Most 87 octane now is E10 (and in my area, 89 is E5 and 91 & 94 are non-blended petrol)
  9. Easy Rider 2
    Easy Rider 2 Senior Member
    1,584
    258
    Ocala, FL
    Pointless discussion......again.
    The octane rating in and of itself says NOTHING about how clean a fuel burns.......or the energy content.......or the amount of detergents in it.
    Octane rating measures ***ONLY*** the fuels resistance to pre-detonation due to compression heating of the fuel/air mix.
    That's it. Nothing else.
    An E10 blend contains about 4% less energy than E0 so the E0 should give you a little better mileage.
    But if the price spread is more than 4%, it is still a waste of money.......just not quite as much.
    At $3.00 a gallon, that 4% would be about 12 cents.
    The price spread lately that I have seen is more like 40 cents.
    So you would be paying an extra 4o cents but only getting a 12 cent benefit.
    #9 Easy Rider 2, Dec 14, 2014
  10. Mendel Leisk
    41,915
    The oil companies fuel (pun intended) the confusion on this topic. Driving into any station, with the plethora of higher octane pumps, it's hard not to think more cars on the road actually need the stuff.
    kenoarto likes this.
  11. slcMPG
    slcMPG Member
    221
    65
    SLC, Utah
    Nope, 87 is all I use and it works great.
  12. bisco
    52,396
    moet of the pumps i run across are three octanes.
  13. rxlawdude
    rxlawdude Active Member
    701
    220
    So Calif
    2015 Tesla Model S
    That's really volatile fuel! ;)
    iluvmacs, F8L and bisco like this.
  14. 2k1Toaster
    6,035
    3,855
    Rocky Mountains
    My Prius loves the 83 octane. Sometimes 85 if I drop down in elevation a few thousand feet.
  15. GregP507
    3,002
    481
    Car and Driver:
    "Our tests confirm that for most cars there is no compelling reason to buy more expensive fuel than the factory recommends, as any performance gain realized will surely be far less than the percentage hike in price."
    Test Results
  16. Tim Wang
    Tim Wang Junior Member
    33
    Central Illinois
    Toyota Hybrid System Technical training course - Course 071, "Fuel Type & Octane Rating", Page 4-17:
  17. Tideland Prius
    16,621
    Yeah up here, 91 costs 15 cents more and 4% yields 4-5 cents, so it's a similar disparity here.
  18. GregP507
    3,002
    481
    Even though it's theoretical.
  19. Tideland Prius
    16,621
    Well it'll mess up your fuel economy calculations since you're not pumping 100% fuel with 87 octane, right?
  20. Epiphany2000
    Epiphany2000 Member
    126
    San Francisco Bay Area, CA
    Put your money in the bank, not in the tank.
    rxlawdude and kenoarto like this.
