best ride lowering springs?
Discussion in 'Gen 3 Prius Accessories and Modifications' started by Prius S, Nov 20, 2014.
  1. Prius S
    Prius S Junior Member
    LBC
    New guy here, looking to lower my 2010 but keep the ride quality, looking for thoughts from the experts.
    But don't want to have to always worry about driveways and speed bumps.
    Tia
    Roger
  2. FishCandy
    FishCandy Active Member
    220
    292
    I would do Tien springs!
  3. Prius S
    LBC
    Do you have them on your car? what is the drop in inches? comfort?
  4. FishCandy
    220
    292
  5. Prius S
    LBC
    Thank you but not looking to go so extreme as a coil over set, thinking TRD springs, Tanabe NF210 etc..
  6. thehybridtheory
    thehybridtheory New Member
    Torrance
    I don't like Tein's customer service. I've never run the Tanabe NF springs but they will probably do if you're looking for a mild drop while keeping ride comfort. After that you're going down the swift racing spring road :D
  7. Xterra72
    Xterra72 Senior Member
    1,432
    1,679
    I like my TRD Springs. Lessens the gap but mild enough it does not scrape. 20141010_074244.jpg
    Burna J and Blizzard_Persona like this.
  8. Mikzwol
    Mikzwol New Member
    27
    Clovis, California
    I have tein they have been great [​IMG]
  9. Blizzard_Persona
    1,787
    948
    Pa.
    2023 Prius Prime
    XSE
    Looks about perfect! I like it a lot.
    Did you do install yourself? If so how hard was it to do? Dealership quoted me $600 to install!!!! And no they weren't kidding...
  10. Mikzwol
    Mikzwol New Member
    27
    Clovis, California
    I am a mechanic and did the install myself it's very easy took me about 3 hours their is a lot of information about doing the installation and some you tube videos
    Blizzard_Persona likes this.
  11. Xterra72
    1,432
    1,679
    I did not install myself. A reliable shop should be able to install for half the price the dealer is quoting you.
  12. Blizzard_Persona
    1,787
    948
    Pa.
    2023 Prius Prime
    XSE
    Would it be silly to lower my persona now as snow is certain to start falling over the next few months.......
    Granted I am In Philly area but last yr was pretty nasty, last couple yrs before not so much...
    Personally I think my persona handles great, dare I say better than my prior muscle /sports car charger r/t.
  13. Xterra72
    1,432
    1,679
    If you need to keep the clearance because of the snow, why not wait till summer to install the lowering springs and install suspension braces for now. It's well worth it. That's exactly what I did.
  14. Sfcyclist
    Sfcyclist Senior Member
    1,621
    376
    SF, CA
    TRD springs here as well. Thumbs up all around, well match for stock dampers, still retains a good ride, handles better and just enough drop.
    Xterra72 likes this.
  15. Chris S
    Chris S Active Member
    323
    109
    Gilbert, AZ
    I'll say the same for my Eibachs ;-) About the same ride and drop as TRD from what I've read. Combined with stock dampers the car still drives great after 18 months and 12k miles
  16. Sfcyclist
    1,621
    376
    SF, CA
    TRD's are re-labled Eibachs from what I read..
  17. Xterra72
    1,432
    1,679
    I agree. I spoke to an Eibach representative and he says that Eibach is a main supplier of performance springs to Toyota.
  18. Blizzard_Persona
    1,787
    948
    Pa.
    2023 Prius Prime
    XSE
    So where is the best price / place to buy either the Eibachs or TRD springs since as stated above they are the same springs.
    Thanks.
  19. Sfcyclist
    1,621
    376
    SF, CA
    I haven't shopped around lately but I bet they hover right around $200. I bet shipping will be the bigger factor.
    Also, alignment needed will be only just the front. The rear being a trailing arm, nothing they can adjust unless they shim it.
  20. Blizzard_Persona
    1,787
    948
    Pa.
    2023 Prius Prime
    XSE
    Thank you for that info. Good to know about the alignment also.
