I have not done any of the Toyota recalls on my 2008 Prius
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by ski.dive, Dec 23, 2014.
  1. ski.dive
    ski.dive Active Member
    964
    244
    Hutchinson Island,FL. Mt. Snow,VT
    OK'
    So I have not done any of the Toyota recalls on my 2008 Prius.
    I now have 67k miles on it and running like a top!!
    Should I worry about it?
  2. Yakoma
    Yakoma Active Member
    470
    125
    sss
    Don't WORRY about it, but take it in to the dealer and get them done. They cost you nothing except some downtime for your car. I think they even have rental allowances for some of the procedures.
    At least one is safety-related (steering column, I believe) and one could cause potential engine damage (coolant pump).
  3. JC91006
    JC91006 Senior Member
    16,761
    8,562
    Is there a reason you haven't done them?
  4. Mendel Leisk
    41,301
    What are the recalls? Coolant pump? Something with the steering linkage? Why not do them??
  5. Patrick Wong
    18,200
    6,500
    Toyota is not in business to waste resources on unneeded recalls. If you believe you have better judgment than the engineers who decided that the recalls are required, then there's no problem in continuing to ignore the recall notices.
    I could understand your perspective if you believe that your local dealer service department has incompetent techs. In that case, it might be reasonable to find a dealer that employs more capable service staff. Since you reside in two East Coast locations, you presumably should be able to find a Toyota dealer somewhere across that 1,300 mile span who can provide reasonable service.
  6. Eclipse1701d
    Eclipse1701d Prius Enthusiast
    645
    224
    Nature coast, Florida
    Three Touring
    Recalls should be, inverter coolant pump ( if it hasn't expired), shave the gas pedal to prevent unintended acceleration (like running over pedestrians or just killing yourself and inconsequential passengers) and checking the steering linkage for a possible defect that has a potential to cause death and carnage... But, when you get around to it... :cool:
  7. bisco
    51,837
    you can skip the pedal shaving if you want, the engineers didn't come up with that one.
