Bought the car...
Discussion in 'Gen 2 Prius Main Forum' started by markrj, Dec 23, 2014.
  1. markrj
    markrj Junior Member
    17
    Hey guys, I posted a thread about buying a used 2005 prius with 130,000 miles. I bought it! I had a good hybrid mechanic review the car thoroughly and seemed okay.
    HOWEVER, I am having an annoying issue with the driver side headlight. When I turn the headlights off and on, it flickers wildly and then turns off. It will not turn back on normally again until it sits for 5 minutes and i only turn the headlights on "on" and THEN turn on the car. It only happens when I am in the car with it on, and cycle the headlights off and on with the knob. If I turn off the entire car and turn it back on (with the headlight knob staying on "on" the entire time), it does NOT happen. So, if I have been keeping my headlights on and havent had any issues.
    Yeah, I bought new headlights (HID, D2R) and had a local mechanic install (All for 120$)...and it still happens. One of the most devastating things! Lol.
    I guess something in the headlight assembly is wrong? Is it bad to just ignore this issue until my headlight gives out completely, or is it just a weird quirk that will be fine as long as I dont turn off my headlights?? Thanks
  2. ePriusdotcom
    ePriusdotcom Junior Member
    Walpole, Massachusetts
    Either you got a bad bulb or you may need to have your ballast replaced.
  3. markrj
    17
    i think my ballast is bad then...any idea how much that costs to replace/how easy it is to do?
  4. ericbecky
    ericbecky Hybrid Battery Hero
    4,416
    3,287
    Madison, Wisconsin
    It's a pain to do. But doable if you have patience and are adventurous . Involves dissecting and reassembling the new replacement ballast.
    Ballast can be $100 to a few hundred dollars. Depends which one you choose.
    There are some good tutorials that I've turned up on Google in the past. Sorry I don't have a link handy right now.
    Edit. Here's a link.
    Toyota Prius: How to Replace the HID Ballast/Computer/ECU - PriusDIY.com
