Lots of low mileage driving - will this ruin a Prius battery?
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by stephgreene, Dec 27, 2014.
  1. stephgreene
    stephgreene New Member
    Hi Prius owners,
    I currently have a high performance car, but since I only live about 2 miles from work, I do a lot of low mileage driving. My daily commute is about 1.7 miles each way, and I live about 3 miles from the grocery store, and rarely go further than 8-10 miles at a time, maybe once every few months I'll drive about 100 miles from home. So I do a lot of low mile trips, and according to the mechanics I've ruined the battery on my current car. I'm wondering if anybody has any insight or experience as to whether this type of driving will ruin a Prius battery. I want my next car to be a Prius C.
    Thanks for any insight.
    52,376
    ya, you might need a battery tender, these 12volts are even more sensitive than normal. a pip would be perfect for you though.(y) on second thought, the battery doesn't mind short trips as much as it doesn't like not being driven for days at a time. with short trips, you won't likely get the epa mpg.
  3. stephgreene
    Thanks bisco. Forgive my noobs, but what's a pip?
    I take it back! Plug in Prius?
    #3 stephgreene, Dec 27, 2014
  4. bisco
    52,376
    PlugInPrius, your driving is a lot like mine, and i drive mostly electric, but the gas is there for those hundred mile trips.correctamundo!:pford cmax energi is a little closer to the prius c, and has a plug.
    #4 bisco, Dec 27, 2014
  5. fuzzy1
    10,602
    Remember that a Prius has two batteries: a common (though smaller than normal) 12V battery, and a big high voltage traction battery.
    The Prius 12V battery will probably suffer similar issues as the 12V in your other car. Because it is mounted inside the passenger compartment air space, it is an AGM type with vent tube to the outside, somewhat more expensive than regular car batteries.
    The traction battery, the expensive one, should not have any problem with your use style.
    But at your short commute distance, are walking or bicycling reasonable options? These would be even better than any Prius.
  6. Easy Rider 2
    Easy Rider 2 Senior Member
    1,584
    258
    Ocala, FL
    Given your usage patterns, a plugin model of anything probably wouldn't justify the extra cost.
    BUT an automatic 12 V small battery charger for ANY car that you use would be a good idea......including your present car until you trade.
    It would be connected overnight (or until the "full" light comes on) in any week that you do not make a 100 mile trip more or less continuously.
    Have you considered an electric bicycle or small scooter ??
    Seriously. Both can be good options.
  7. stephgreene
    Thanks everybody for the feedback. I actually used to solely commute by scooter (100mpg Honda Metropolitan), but it's just not feasible now even though it was super fun. I'm constantly running around after work, and I'm usually running late, so adding an extra 10-20 minutes to just get to my car isn't a good idea for me. My gym is 5 miles away on a major highway, so I can't scoot or bike that (I forgot about that one in my original posting, probably because I rarely go, but I want to change that and my plan is to start going every day after work!). And unless I can put solar panels on my roof, I'm not getting a plug in. In my townhome I do not own my roof and my HOA forbids it.
    ftl likes this.
  8. Easy Rider 2
    1,584
    258
    Ocala, FL
    OK, then you NEED a small automatic charger, regardless of what kind of car you have or get.
    That is assuming that you have a parking place close to a power outlet.
    P.S. showing in your profile that you ALREADY have a C might be a tad confusing at some point.
  9. stephgreene
    [QUOTE="P.S. showing in your profile that you ALREADY have a C might be a tad confusing at some point.[/QUOTE]
    They wouldn't let me register unless I checked off which Prius model I have!
  10. fuzzy1
    10,602
    I realize that biking isn't for everyone or everywhere, but can't let you off that easy :) ...
    When I was bike commuting, work was 17-18 miles away. I didn't pedal that more than twice a week, but numerous others did. And the average one-way distance for fellow pedalers was more than 5 miles. But this is also a very bike-friendly area, many other locations are downright hostile.
    A major part of regular cycling is learning the good bicycle routes, which are often quite different than the equivalent driving routes.
    Is 'Other non-hybrid' visible? You can still change it.
  11. Easy Rider 2
    1,584
    258
    Ocala, FL
    Yet I see that you have found the proper choice now !! ;)
  12. FireFire
    FireFire Member
    101
    Ontario, Canada
    Maybe Volt? about 200km per charge vs prius plugin only 40km per charge...
  13. Easy Rider 2
    1,584
    258
    Ocala, FL
    Maybe. I considered a Volt but owners report a really LOT of annoying problems with them; some serious and some not so much.
  14. My driving pattern is pretty much the same (1-2 miles to work, same back), plus supermarket trip twice a month. Doesn't matter to me, the 12V battery should just work.
  15. Matt H
    Matt H Active Member
    164
    105
    Okinawa Japan
    2012 Aqua
    No harm to the batteries, but not good for the engine. Driving like that, the oil temp never gets hot enough to evaporate moisture and contaminants from combustion. This leads to sludge build up, and premature engine wear. About once per week, you should get it good and hot.
  16. Easy Rider 2
    1,584
    258
    Ocala, FL
    Well it DOES matter to you. Your 12 V is working.......now. It might not work for long without a change in your driving habits though (or an additional maintenance step that most don't have to do). When you design a machine like this, you can not engineer for EVERY possible different usage pattern. This situation is not unique to the Prius among hybrids. It even happens to a conventional car design, it just happens easier and more often with the smaller battery.
    Actually it probably will harm both.
    A good 30 mile run once a week will probably take care of both issues.
    Every two weeks and less than 30 miles probably won't get it over the long run.
    Bottom line: If you can't or won't change your driving pattern, you NEED to use the "severe service" recommendation for oil changes AND you NEED to fully charge the battery somehow once a week.
  17. Will the 12V battery charge in EV mode/engine off but car on?
  18. Easy Rider 2
    1,584
    258
    Ocala, FL
    By that, do you mean pushing the power button without having your foot on the brake ?
    I think the answer is NO because once the car is truly ON the engine will run if it needs to........for a host of different reasons and only one reason is to propel the car down the road.
    If you put it in RUN mode, which really is ON for everything, then is will charge the 12 V from the other battery and then run the engine when the HV battery gets low. I don't think it will do any of that if not in the RUN mode.
  19. edthefox5
    edthefox5 Senior Member
    10,096
    4,834
    Clearwater, Florida
    He means EV not accessory.
  20. bisco
    52,376
    i don't see why not.
