Icncrease MPG with taller tire
Discussion in 'Gen 2 Prius Fuel Economy' started by etyler88, Apr 4, 2006.
  1. etyler88
    etyler88 etyler88
    450
    Dover, DE
    The OEM Goodyear Integrity 185/65-15 is 855 rev/mile. If 185/75-15 size were put on 855 rev. would be over a mile. So my theory is a larger circumfrance tire would bump up the milage.
    Anybody tried this and can the spedometer be adjusted?
  2. jbarnhart
    jbarnhart New Member
    629
    Santa Clara, CA
    It's not that simple. Larger diameter does not equal higher milage. If it did, all those SUVs on the 25-in hoops would be getting a zillion MPG. Also, there isn't a known way to recalibrate the MFD for a different diameter tire. (Although Prius is sold with different wheel options in Japan and Europe so it might be buried somewhere in the service menus, but we just haven't found it.)
  3. benighted
    benighted New Member
    530
    Westport, WA
    The Prius is desigigned to tell you you are going a little faster than you really are so putting on taller tires might actually make the speedometer more accurate while the Odometer will be a little slower.
  4. dipper
    dipper Senior Member
    1,242
    252
    Got to be careful about trying this though. The rear wheel well might not be able to properly fit though. The larger tires could rub the rear wheel well when making turns.
  5. Red Ginger
    Red Ginger New Member
    43
    Hawaii
    <div class='quotetop'>QUOTE(benighted @ Apr 4 2006, 09:01 PM) [snapback]235151[/snapback]</div>
    Wow, this is like setting my alarm clock five minutes ahead so I won't be late in the morning. Problem is, I always know I've set it ahead, so it never really works.
    How much faster does the Prius speedometer say you're going than your actual speed?
  6. Tom_06
    Tom_06 Active Member
    609
    142
    Newark, Delaware, USA
    <div class='quotetop'>QUOTE(benighted @ Apr 5 2006, 03:01 AM) [snapback]235151[/snapback]</div>
    There must be something wrong with mine. When I check it with a WAAS enabled GPS on a straight road (GPS accuracy +/- .05 mph) my 2006 seems to be exactly correct within rounding to the nearest whole mph number (that is, 45 mph rather than 44.5 through 45.4).
    OEM tires at 40/38.
    If you want to play with tire size changes, a good calculator showing mph variation from standard is at http://www.miata.net/garage/tirecalc.html . Note that normally putting on larger wheels is done with a lower profile tire so that the effect on your speedometer and odometer accuracy is little to none.
    - Tom
  7. etyler88
    etyler88 etyler88
    450
    Dover, DE
    What are the sizes?
  8. etyler88
    etyler88 etyler88
    450
    Dover, DE
    euro/japan option is 195/55-16
  9. vikingrob
    vikingrob New Member
    37
    Minneapolis, MN
    <div class='quotetop'>QUOTE(etyler88 @ Apr 4 2006, 09:33 PM) [snapback]235039[/snapback]</div>
    You're not the only one looking at it - a number from the TDI crowd have done likewise. One went from the OEM 205-55-16 to 205-60-16, and I'm looking at taller tires as well.
  10. Tideland Prius
    16,602
    Most cars have faster-than-actual speedos. Oddly, the Prius is fairly accurate. Maybe it's because they think we won't speed in it lol. Even when Driving Television did their 200km Hybrid Commuter Challenge, the Prius was the only car to show exactly 200km on the trip odo. The Accord was worse at 201.6km I believe.
  11. ken1784
    ken1784 SuperMID designer
    2,943
    1,384
    67
    Yokohama, JAPAN
    <div class='quotetop'>QUOTE(etyler88 @ Apr 5 2006, 11:33 AM) [snapback]235039[/snapback]</div>
    Do you know how a final gear ratio is selected?
    And, do you know why does Toyota set it 4.113 for Prius?
    No, the spedometer can't be adjusted.
    Ken@Japan
  12. etyler88
    etyler88 etyler88
    450
    Dover, DE
    NO
    NO
    Please give the answer.
  13. benighted
    530
    Westport, WA
    <div class='quotetop'>QUOTE(Red Ginger @ Apr 5 2006, 02:43 AM) [snapback]235180[/snapback]</div>
    mine runs about 3 to 4% over actual speed
  14. hycamguy07
    hycamguy07 New Member
    2,707
    Central Florida
    :huh: Huh??? The Prius is desigigned to tell you you are going a little faster than you really are ..
    Umm what is that again?
    Lets see the speedo reads 45mph, per the stalker radar clock the cars doing 45mph. So the radar gun is telling the user your going faster than you are..?.. :blink: :wacko:
    I put the taller tires on my 04 what a mistake, it now tells me in getting worse mpg's ....
    Sounds like someone needs thier speedo recalibrated..
    I know most cars can be off by 2-5 mph slower or faster but this can be fixed by recalibration not sure if the prius can be done though..
  15. ken1784
    2,943
    1,384
    67
    Yokohama, JAPAN
    <div class='quotetop'>QUOTE(etyler88 @ Apr 6 2006, 04:22 AM) [snapback]235407[/snapback]</div>
    So...
    What kind of technology are you talking about in your theory?
    Ken@Japan
  16. etyler88
    etyler88 etyler88
    450
    Dover, DE
    priusguy 04
    what size tires did you put on?
    have you done MPG by pen and paper or determined if speedo/odo is off?
  17. benighted
    530
    Westport, WA
    <div class='quotetop'>QUOTE(priusguy04 @ Apr 5 2006, 07:16 PM) [snapback]235626[/snapback]</div>
    <div class='quotetop'>QUOTE(ken1784 @ Apr 5 2006, 12:14 PM) [snapback]235402[/snapback]</div>
  18. BVISAILMAN
    BVISAILMAN Junior Member
    85
    Marlborough, MA
    IF the SPEEDO is off so will the ODO be off, so doing MPG with paper and pen will not be accurate.
    Only way I know would be to drive exact course that you already know, and calculate MPG based on that when filling up.
  19. benighted
    530
    Westport, WA
    <div class='quotetop'>QUOTE(BVISAILMAN @ Apr 10 2006, 12:43 PM) [snapback]237648[/snapback]</div>
    Not necissarily.
    Can manufacturers can make the ODO accurate while inflating the MPH on the SPEEDO.
  20. Kaos1
    Kaos1 Junior Member
    Mid-Alantic
    I might be wrong, but dosen't it take more horsepower to turn bigger wheels? Accelerations might be slower, the indicated speed would be slower, and the indicated MPG would be less.
    Kaos1
