12v Battery issues
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Beammeupscotti, Dec 29, 2014.
  1. Beammeupscotti
    Beammeupscotti Junior Member
    I have a 2007 base prius that has around 198,000m on it. Recently, I had the master warning light (red triangle !), the brake light (!), and the check engine light come on. My car was not acting funny until half way home and I noticed the acceleration was a bit sluggish. When I got home, I looked at the diagnostic screen (not with engine on) to see that my 12v battery was at 9.4v, which I then bought a new one and replaced it. Now the new 12v battery was around 11.6v. The issue seemed to be fixed, the car drove fine, and the light went away, but about 48 hours later the three lights appeared again with more sluggish acceleration. Now my battery fan (rear passenger side vent) kicks on randomly. I can't seem to figure out what is wrong with it now.
    I think that it has to do with the fact that the battery I bought was the larger one made for cars with smart key (which I do not have) and we had to take the battery brackets out and put foam padding around the bottom of the battery to keep it from moving. We didn't block the vent or fan at all however so I am not sure why the fan keeps coming on. I am looking for a smaller battery that I can buy but no luck yet. So I guess my questions to you all would be:
    Could the problem/errors be because it is a larger battery?
    Any ideas on where to find the smaller battery replacement?
    Do bad 12v batteries cause the sluggish acceleration or is that another problem?
    How do I check the battery fan for issues?
    Thanks for any help! (also, I know that I can take it to the Toyota dealer but I am trying to troubleshoot it here first)
  2. JC91006
    JC91006 Senior Member
    16,761
    8,562
    I think you are OK with the bigger battery, as long as you make it fit in the rear compartment (you can buy the proper bracket). This battery is partially drained if it's a new battery. You should actually return/exchange it as it should have been 12.5 volts or higher when you first get it. That however is not the problem to your acceleration and fan coming on.
    You should get the DTC codes read on the car. Most likely issue is the bigger HV battery going bad. That can mean big bucks $2500- $3000 new from Dealer.
    xpcman likes this.
  3. Beammeupscotti
    Thanks for the reply. I don't have the P1 codes yet (I need to go down the an autopart store) but I do have the codes logged from the LAN monitor screen:
    01-D5 190-48-F
    01-D5 1C6-7C-2
    01-D8 190-10-1
    01-D9 190-7A-3
    01-DC 190-9F-F
    01-DC 1C6-CC-F
    01-DC -7C-F
    What are the symptoms of the bad HV battery? This happened so suddenly that I was hoping that it wasn't the HV battery.
  4. JC91006
    16,761
    8,562
    Leading up to the failure, your car State of charge meter should have fluctuated from full to empty quite quickly. The warning lights coming on, passenger compartment fan coming on, sluggish acceleration are all symptoms of a failing HV battery. When you replaced the battery, you were able to reset the car for 48 hours before the ECU picked up the failing battery again.
    This could also point to a failed inverter pump which overheated the car. However since you were to go 48 hours without any issues, this would point more towards the battery.
  5. Patrick Wong
    18,200
    6,500
    Could the problem/errors be because it is a larger battery? No. However measure the voltage on the 12V battery when the car is IG-OFF and when the car is READY. If the IG-OFF voltage is less than 12.6V, fully-charge the battery now. If the READY voltage is much less than 13.8V, the root cause of the problem is the DC/DC converter is not working.
    Any ideas on where to find the smaller battery replacement? Your Toyota dealer's parts counter. That is not necessary if you install the correct longer battery bracket used with the Smart-equipped Prius. You don't want the battery to be loose in the back of the car as that is not good for the battery's service life and also constitutes a potential safety hazard.
    Do bad 12v batteries cause the sluggish acceleration or is that another problem? Another problem
    How do I check the battery fan for issues? Listen at the vent to the right of the rear seat back cushion, but that probably is not the issue in the dead of winter assuming you live in North America.
    If you are serious about DIY troubleshooting your car's problems, get a digital multimeter and Mini VCI so that you can gain some clues about what is wrong.
    Eclipse1701d likes this.
  6. Beammeupscotti
    Just an update for anyone reading this with similar issues...
    I got the P0A80 code for HV battery replacement. I took the HV battery out, along with the extremely dirty battery fan, and tested the cells. All were 8.1 except one which was 6.8 (obviously the bad one) and another one that was 8.06. I ordered one replacement cell but do anyone think I need to replace the 8.06 cell also?
  7. bisco
    51,833
    no, but be aware that a fix like this is temporary at best.
  8. Beammeupscotti
    How so?
  9. bisco
    51,833
    battery balancing is serious business, involving load testing and special chargers. there are many threads here about how it should be done, and many threads from people who have just popped in another cell. some are disappointed, and some are comfortable pulling the battery every few months to rinse and repeat.
  10. nh7o
    nh7o Off grid since 1980
    1,686
    340
    Hawaii
    Those numbers aren't of any use outside of the LAN, i.e. the MFD, audio stuff, Nav system, which is not part of the OBDII bus. Makers know that self diagnosing cars are not as profitable as ones that just light up scary lights.
