Curb check...
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by TardisBlue, Dec 31, 2014.
  1. TardisBlue
    TardisBlue New Member
    Cincinnati, Ohio
    Hi all -
    I tried to do a search, but didn't find anything too similar from my issue. If there's one and I missed it, just point me to the right place!
    So I've had my new Prius Two about a month and did something very stupid. While leaving a small parking lot in a downtown area, I miss-judged where the driveway was and drove off the darn curb. I wasn't going very fast probably about 5mph, maybe a little more - I had pretty much just taken my foot off of the break to let the car coast out into the street (it was narrow with cars parked along each side, so I wasn't trying to peel out or anything for sure). It made an awful sound in the front without much noise from the back, but I drove home with no problems - no weird or new sounds, vibrations, etc.
    Looking underneath, there doesn't appear to be anything scratched, dented or bent and no fluid is leaking. There's still no new or unusual sounds and no vibrations at any speed - drives the same as far as I can tell. I was concerned about the alignment, so I took it in to the dealer and had one done mainly for some piece of mind there. I've done the driving slow in an empty parking lot test, and it drives straight as I'd expect.
    2 of the cars I had previous to this one were both complete nightmares - if it could fall apart, fall off or leak, it did - so I think I'm pretty much scarred for life and keep thinking the worst. I know Toyotas in general are pretty reliable, but this is also my first brand new car (AND the exact car I wanted), so I'm basically kicking myself nonstop over doing something so dumb - especially since I'm usually a pretty decent driver. Since nothing appears to be out of the ordinary or scratched/dinged up, should I be ok?
    Oh, and I will NEVER do that again!
  2. css28
    css28 Senior Member
    1,566
    443
    Suburban Detroit
    It sounds as if you're fine.
  3. GrGramps
    GrGramps Active Member
    294
    176
    Western North Carolina
    Most of us, given time, will do something stupid. If you had bent some part of the front suspension the alignment tech would have certainly noticed and suggested replacing the part.
    So you got away with it. DON'T DO IT AGAIN!!
  4. xliderider
    xliderider Senior Member
    8,140
    3,277
    Honolulu, HI
    The sound you heard was probably just the suspension hitting up against the rigid bump stop that limits suspension travel. Hopefully, nothing was bent or damaged. It's good you were going very slow.
  5. bisco
    52,395
    join the club.:p you may have scraped the plastic aero panels underneath. if nothing is hanging down, you're probably fine.
  6. Easy Rider 2
    Easy Rider 2 Senior Member
    1,584
    258
    Ocala, FL
    Indeed. Those "air dam" lowers will scrape again, it's just a matter of time.
    Sounds terrible but they are made rather soft and flexible on purpose.
  7. TardisBlue
    Cincinnati, Ohio
    Thanks, guys. I certainly didn't go off the curb all Dukes of Hazzard style :eek:, but I am thinking (and hoping) I got off lucky - the only price I paid is/was to my anxiety level. Nothing is hanging down or leaking, rims and tires look fine and still no vibrations or strange noises after nearly a solid week of driving. I would hope the mechanic that did the alignment yesterday would notice anything bent or needing replaced already that would bring in some money. Oddly enough, I'm not too worried about the plastic under panels getting scratched up since that seems pretty much unavoidable over the life of the car - those look fine enough to me for now anyway. I didn't even know they were there until looking up underneath it after my blunder!
    And no, I won't do it again. :oops:
    Burna J likes this.
  8. JimN
    JimN Let the games begin!
    7,028
    1,117
    South Jersey
    Tardis, welcome to the club. Sooner or later everyone is going to bottom out. Sounds awful but usually there is no damage. If it was as bad as you feared, the guy wouldn't have been able to do the alignment.
    I hope you got it entirely out of your system. That first scratch is going to hurt.
  9. mmmodem
    mmmodem Senior Taste Tester
    2,732
    1,703
    Bay Area, CA
    If you call this stupid, then I've done at least 5 stupids to my Prius thus far. I don't worry about it.
  10. bisco
    52,395
    yup, i always say, 'this is the last time'...:p
    mmmodem likes this.
