2010 Prius External Mirror Black Trim
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by AlanInAustin, Jan 1, 2015.
  1. AlanInAustin
    AlanInAustin Junior Member
    Prius was backed out of the garage and the left external mirror clipped the garage door jamb. The black trim piece surrounding the mirror broke and I'm looking for a replacement but can't find one. I'd appreciate suggestions on where to shop. (I've tried a couple of places but apparently I'm not coming up with the right incantation of terms as I keep getting add-on kits and such to fancy up the mirror. Is there some special set of terms I can use to skinny down search results?)
  2. JC91006
    JC91006 Senior Member
    16,769
    8,567
    AlanInAustin likes this.
  3. AlanInAustin
    Thank you.
    The part I need is the black trim piece which fits between the mirror surface and the cowling/housing for the mirror itself. This appears to be part #4, but it seems a shame to have to buy that whole thing for only the small plastic trim piece. Is that what I really need to do?
  4. JC91006
    16,769
    8,567
    That is just the trim piece for that price. The entire mirror is much more
  5. AlanInAustin
    I just called Camelback to place the order and, when I talked with the guy there, he insisted that I needed to make a specially ordered part of around $300 because that trim piece wasn't a serviceable part. Should I just say "forget it" and go to my local Toyota dealer? Kinda confused right now...
  6. JC91006
    16,769
    8,567
    oh what you have is not a broken cover, it's actually the mirror housing. You would have to buy the entire mirror.
    I think you can superglue it back on if you can find the broken piece.
  7. AlanInAustin
    Unfortunately, it broke into multiple, tiny pieces. I may see if I can just do something to camouflage the damage. *SIGH*
