Lexus LF-NX turbo...Akinson...Otto...Turbo ?
Discussion in 'Lexus Hybrids and EVs' started by Justdidit, Jan 6, 2015.
  1. Justdidit
    Justdidit LVNPZEV
    1,880
    711
    75
    Carrollton, Texas
    Four Touring
    Ok.. I know... its not a hybrid... but I feel that Toyota/Lexus dropped the ball on this one..
    Lexus jumps head first into turbocharging with its 2015 NX 200t
    With the hybrid version only getting a few more MPGs and barely less HP...
    Turbo 235HP 28MPG
    Hybrid 194HP 33MPG
    Burna J likes this.
  2. Tideland Prius
    16,547
    It's an impressive engine, even if output isn't particularly great (BMW's 2.0 litre turbo: 241hp@5,000-6,000rpm/255lb-ft 1,250-4,800rpm). First time I've seen peak horsepower over a range of rpm. It is up on mpg over the X3 xDrive28i's 24mpg combined.
  3. Justdidit
    Justdidit LVNPZEV
    1,880
    711
    75
    Carrollton, Texas
    Four Touring
  4. Trollbait
    12,501
    I think it is just the just time you've seen it published that way. Horsepower is calculated from torque and engine speed. Depending on how quickly the engine's torque drops off after reaching peak horsepower could lead to a peak horse power range. Torque goes down, rpms go up, and the calculated hp remains the same. Or just close to the same.
    Below is a chart of the torque and horsepower of the Sonic RS. Notice the curve after peak hp appears nearly flat. The actual measured horsepower along that line is probably close enough that marketing could could label peak hp with a rpm range.
    . The reported peak for cars isn't where the engine operates at most of the time to begin. Just knowing maximum output is generally enough. Knowing that you can go past that peak rpm without losing power might be helpful in a few cases, but what it really tells you is that you can make the same power while burning more fuel. That's better than making less while burning more, but these engines will be spending most of their time
    Powertrain Overview
    Tideland Prius likes this.
  5. Tideland Prius
    16,547
    Thanks for the explanation! I typically see the power curve depicting peak horsepower as just that - a peak. I guess there's a limit as to how much power can vary after the peak that allows the manufacturer to publish a range rather than one point. Or maybe it's a modern turbo thing? (I haven't seen any power curves for modern turbos, the one I've seen were for NA engines).
  6. Trollbait
    12,501
    I haven't looked at many power graphs, but knew hp was calculated from torque and rpms. Between all the engine types and drivetrain configurations, I just figured this couldn't have been a true first of peak horsepower having a range. The first graph my search came up with was for a F150 Ecoboost dyno test. They reported 302.7 peak HP, but the curve was shallow enough there that could call it 300hp over 500rpms.
    Torque is value most people should be paying attention to anyway. It is what they are feeling during acceleration, and with most driving an automatic here, they probably will never get their car to peak hp on anything near a regular basis.
