10K oil change, the party line?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by IABoy987, Jan 6, 2015.
  1. IABoy987
    IABoy987 Member
    210
    85
    Iowa
    2018 Prius Prime
    MY dealer says the official Toyota party line is change oil every 10K miles or once each year which ever comes first.
    What say all you all knowing, all wise Prius gurus? I don't mind changing at 5K when the display starts announcing its time, and to my non-automotive mind, more changes the better to get the gunk out of the engine. Prius came with 0-5W synthetic oil if that makes any difference for discussion.
  2. Paradox
    29,110
    8,592
    201
    2014 Prius v wagon
    Moved from technical to maintenance
  3. frodoz737
    frodoz737 Top Wrench
    4,720
    2,517
    33
    Your responses are going to be quite polar, as is any oil discussion on a car forum. Will your engine blow up if you only change it every 10K...no. However, many Prius owners have complained of oil burn/usage around 100K...even some GEN II's that had scheduled changes at 5K. Bottom line is if you check your oil regularly and take care of your car...it will take care of you. I personally change mine at 5K.
    Let the games begin.
    Yakoma likes this.
  4. vskid3
    vskid3 Active Member
    773
    228
    5k reminder is there to be a maintenance reminder, not necessarily an oil change reminder. There are other recommended services that are on a 5k miles like rotating the tires.
  5. bisco
    52,390
    i changed mine at 5k, then, every 10k. just to get the initial crud out. don't forget, you engine isn't running all the time, and 10k is the current standard for synthetic motor oil.
  6. goldfinger
    goldfinger Active Member
    535
    403
    Buffalo
    10k is crazy unless your talking full synthetic.
  7. bisco
    52,390
    that's what i'm talkin' 'bout.(y)
  8. Epiphany2000
    Epiphany2000 Member
    126
    San Francisco Bay Area, CA
    I use name brand dino oil & change every 5k.
    As has already been stated, just change your oil, that's what counts (and don't use some no-name sale-of-the-week brand).
    #8 Epiphany2000, Jan 6, 2015
  9. Patrick Wong
    18,210
    6,513
    OP has a Gen 3 model, where the specified engine oil is 0W-20 full synthetic. That being the case, a 10K mile (or annual, whichever comes first) change interval is reasonable.
  10. cmoore50
    cmoore50 Junior Member
    Nothern IL
  11. Mendel Leisk
    41,901
    I follow the Toyota Canada 8000 km (roughly 5000 mile) or 6 month interval.
    Especially with it being the 6 months typically governing, the drained oil looks pretty good still. But it's cheap, and gives me something to do. ;)
  12. Easy Rider 2
    Easy Rider 2 Senior Member
    1,584
    258
    Ocala, FL
    That display is announcing that it is time for SOME routine maintenance, not necessarily an oil change.
    Tires are supposed to be rotated at 5K intervals.
    Personally, I intend to compromise and do both rotation and oil sometime around 7.5K.........and deprive the dealer of an extra opportunity to find something else expensive than "needs" to be done. :)
  13. Oldwolf
    Oldwolf Prius Enthusiast
    826
    110
    NC
    2016 Prius v wagon
    10k mile oci's is all I have done with my Prii and I do use the appropriate weigh synthetic in each of them.
