Lower MPG with new tires.
Discussion in 'Gen 3 Prius Main Forum' started by geegecko, Dec 8, 2014.
  1. geegecko
    geegecko Junior Member
    Charleston, South Carolina
    I recently replaced the factory Yokohama 195-65-15 on my 2011 Toyota Prius II with a set of Michelin Defender. MPG has dropped to 45 mpg for city driving. With the Yokohamas, I was averaging 49 mpg.
    Is this typical?
    Thanks in advance for any information.
  2. frodoz737
    frodoz737 Top Wrench
    4,719
    2,517
    33
    Yes, but only for a short period of time. Real world difference between the Yoko's and Defenders after break in is more like 1-2 mpg less if you get really anal about it. My Defenders have over 40K miles now and about 70% legal tread. The Yokos (remaining 3) were near bald and replaced by this time before. The Energy Savers are reported to get 1-2 mpg better than the Yokos, but are rated for 60K miles vs 90K miles on the Defenders.
    F8L likes this.
  3. dorunron
    dorunron Senior Member
    3,318
    1,105
    Houston, TX
    As frodo said, perfectly normal. New tires are actually a little larger in circumference which affects the MPG calculation. Also the tires are NOT broken in, so the tread is not rolling as easily as a used tire will.
    Give them a few tanks of gas and some time, and your MPG should return. The defender is a LRR type tire, but there are better one's out there. But if you are interested in getting GOOD longevity from your tires, then you made the right choice IMO.
    Finally, "Welcome To Prius Chat"!
    Ron (dorunron)
    amos and F8L like this.
  4. B. Roberts
    B. Roberts Hypah Milah! Ayuh.
    691
    212
    used to be "Glacial" Maine and now FL
    LRR tires from different brands can perform quite differently. A friend put a set of Conti PureContacts with EcoPlus Tech on his 2010 Prius Hatchback. He keeps them at 38/36 front/rear and has lost about 3-5 mpg compared to the old OE Yoks. But they ride really nicely and are very quiet. The car was fairly linear with the old tires, but now it's even better. He has about 5K or a little more on them now, so are broken in. Unfortunately, he had the update done the same day that those new Contis were put on. So this particular tire/MPG comparison may be skewed a tad.
  5. 14T shelley
    14T shelley Junior Member
    43
    We put Michelin Energy? tires on our 13 after the Yokohama tires wore out. We gained 2 MPG by doing so. The rest of the story is that the salesman talked my wife into the Continental Pure Contact tires telling her that they definitely would increase the fuel economy and if she didn't like them then she could return them within 2 weeks and exchange them. They were on the car for 400 miles and the milage dropped by 5MPG. Car went back to the tire shop, Conti's came off and the Michelins went on.
  6. F8L
    19,011
    4,083
    Grass Valley, CA.
    Yes, two different categories of tire (standard vs. grand touring). You trade traction, especially wet traction, and handling for fuel economy and a little more comfort. Tires are all about trade offs. :)
  7. Mendel Leisk
    41,882
    Have a look at Michelin's web site, their rolling resistance ratings of several Prius options:
    Energy Saver: 10
    Premier A/S: 9
    Defender: 8
    2010 Toyota Prius Base Tires | Michelin Tires
    Your mpg will pick up a bit over time, with extra effort on your part may get close to your previous results, but it will be an uphill battle.
  8. kc410
    kc410 Active Member
    263
    255
    2010 Prius IV
    I went from well worn Toyo Versado eco to the Defenders & initially took a small but noticeable hit. After >20K I'm back to about the same mileage as before. On both the old & new tires I run max pressure on the sidewall (44psi) in all 4 tires. Most of my driving now is with a hitch mounted bicycle rack installed - higher tire pressure helps lots!
  9. Tandem Rider
    Tandem Rider Junior Member
    56
    Indianapolis, Indiana
    I also went from Yokahamas to Michilin Defenders. My milage dropped 2 to 3 mph. The Defenders are noticeably quieter and are rated to last much longer than other LLR tires.
  10. bisco
    52,371
    more than pay for themselves with $2. gas.;)
    F8L likes this.
  11. cyclopathic
    cyclopathic Senior Member
    3,292
    547
    2014 Prius c
    went from Yokohamas to Michelin Savers A/S and mileage had gone up 2 to 3 mph. The Savers are noticeably quieter, and lasted 70K.
    Thread wear on Defender is rated at 820 and on Saver 480, so Defender could potentially last ~120K. Issue is that tires are usually no good after 3 years, so unless you drive 40-60K a year you are unlikely to benefit from it.
  12. bisco
    52,371
    3 years?my miata tyres were 10 years old!:eek:
  13. cyclopathic
    3,292
    547
    2014 Prius c
    my Spitfire tires are 16 years old and look very good, but they are kept in garage on blocks.
    anything driven daily in harsh conditions will start to deteriorate after 3 years. 5 years is the upper limit, YMMV
  14. GregP507
    GregP507 Senior Member
    3,002
    481
    I don't know my tires well enough to say for sure about your tires, but rolling-resistance is a factor in fuel-economy. I don't know if there is a definitive rating-scale for this, but a real-world indicator (besides calculated mpg) is the temperature of the tires after driving. The energy lost to rolling-resistance is converted to heat.
  15. bisco
    52,371
    i agree it's probably mostly related to climate and use. another thread says that nhtsa claims six years, but no one knows what's going on inside a tyre.
  16. cyclopathic
    3,292
    547
    2014 Prius c
    this is $450 question (for Prius owners anyways). From unscientific experience looking at discarded tires I suspect safety-wise most will be fine for quite some time past 3-5 year range. But they tend to loose grip and ride quality, so I tend to budget for ~3 years. Doesn't make any sense to buy tire which will last less then 2 years, and no reason to buy ones which will go more than 4; just saying.
    If we have rain to clear salt I'd post a pic of ~3y.o. Mich Saver with micro cracks. The OEM Yokos looked very similar in less than 2 years, so it is definitely tire/rubber compound dependent too.
