My 2012 Prius 5 Build
Discussion in 'Gen 3 Prius Accessories and Modifications' started by Accordlayingkit, Nov 9, 2014.
  1. lverasky
    lverasky New Member
    Very nice write up, I came from FR-S forum. Done some mods too, glad to see your mods in the Prius. It is very cool. And I am gonna using your instruction to work on my Prius soon too. Btw I just got my 2015 Prius last night, pretty exciting for it
    Accordlayingkit likes this.
  2. Accordlayingkit
    Accordlayingkit Senior Member
    1,618
    1,748
    377
    Colonial Heights, Va
    Thank you and congrats!
  3. BPZVW30
    BPZVW30 Member
    73
    141
    Your car looks awesome Accordlayingkit.
    I like what you did with the headlights. I would like change the color of orange reflector to silver, but "baking" them is just not something I'm comfortable with right now.
  4. Accordlayingkit
    1,618
    1,748
    377
    Thanks I appreciate it.... yea it's pretty stressful doing the baking of the headlights... especially with having 2 young kids running around and making sure there not messing with anything I have apart and with my work schedule(rotating shift work) nothings easy for me anymore haha
  5. prinut
    prinut Pri Nut
    102
    SouthFlorida
    Really Nice work!!
    Congratulations!
    Now you've made a lot of people dis-satisfied with their ride!!! LOL!
  6. Accordlayingkit
    1,618
    1,748
    377
  7. saulbassfan
    saulbassfan Senior Member
    979
    3,108
    Southern California
    Great build! After reading your thread I now have a bunch of other things to add to my list. Thanks lol
  8. prinut
    prinut Pri Nut
    102
    SouthFlorida
    Same here!!
    Now I have to redo my budget for 2015!!!!!
    saulbassfan and Accordlayingkit like this.
  9. Harris_BRG
    Harris_BRG Junior Member
    40
    Houston
    Where did you get the lexus white floor and glove box leds? how was the install?
  10. Accordlayingkit
    1,618
    1,748
    377
    I'll look for the link when I get to work n a few. But I basically jus search the part numbers u see on the packages on any Lexus dealer website. Install was nothing to it!
    Here Ya go... I bought 3 so I could do the glove box as well
    Lexus Parts - Lexus Parts - Genuine OEM Lexus Auto Parts & Accessories
    #50 Accordlayingkit, Jan 24, 2015
    saulbassfan likes this.
  11. Bill Bremner
    Bill Bremner Junior Member
    27
    26
    Sarasota, FL
    Scott,
    A couple of questions. I purchased the Engine Room Cover Set. How in the world do I install the Large Piece. The radiator overflow tank is a piece of cake, but not sure on the large piece. I also received the large bracket, but have no idea of where that goes.
    Other question. When I sprayed the engine cover with Plasti Dip, I got lots of bubbles in the fin area. What did you use to clean it before spraying?
    Bill
  12. sfprankster
    sfprankster Active Member
    444
    490
    Santa Cruz Mountains, CA
    Denatured alcohol works wonders to clean grease and oil, and leaves no residue.
  13. Bill Bremner
    27
    26
    Sarasota, FL
    I tried that. I stripped the Plasti Dip. Tomorrow I am going to scrub the cover first with soap and water, then retry the Denatured Alcohol. Should I do many light sprays or a few heavy sprays?
  14. sfprankster
    444
    490
    I always use multiple light sprays, usually at least 4-5 with PlastiDip to get an even coverage.
    If you are using the pearlizer or metalizer, I would change to a more "wet" coat.
    #54 sfprankster, Jan 30, 2015
  15. Bill Bremner
    27
    26
    Sarasota, FL
    Thanks, I will give that a try tomorrow.
  16. sfprankster
    444
    490
    Best of luck!!
  17. Bill Bremner
    27
    26
    Sarasota, FL
    Thanks, I may need it.
  18. bingee3
    bingee3 Active Member
    171
    105
    Michigan
    Beautiful looking car , excellent work ,, would like to hear more about the DRL
  19. Johnsk93
    Johnsk93 Senior Member
    212
    1,055
    San Jose, CA
    What springs are you riding on? How low did you drop your prius?
  20. Accordlayingkit
    1,618
    1,748
    377
    Well @sfprankster jus did a nice write up on the engine cover here
    sfprankster's (mis)adventures modding a 2014 Prius Model Three | Page 7 | PriusChat
    I tried to cover to much too much when spraying the engine cover the first time and I didn't even think about cleaning it with anything. Had it bubbling up everywhere! I peeled it off then jus put some dawn dish detergent in a buck of warm water and scrubbed it with a brush, sprayed it off, let it dry the sprayed a bunch of lite coats without trying to cover too much at once and turned out fine.
    Thank you very much!
    Tanabe DF210's 1.3" front and 1.6" in the rear
