Help popping fend joint back together!
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Phil_in_CA, Jan 27, 2015.
  1. Phil_in_CA
    Phil_in_CA Junior Member
    Central California
    Hi all,
    I am a new forum member, but my wife has been a member (or at least a lurker...) since we bought her 2008 Touring.
    A couple of days ago, while on a small highway, a dog ran out from a orchard and onto the road in front of us! I managed to move across the road and managed to only kiss it with a glancing blow on the front right corner panels, right under the headlight. The dog was big, like a pit bull, but apparently unharmed as it ran off so fast I couldn't see it, once I was stopped.
    The upshot of this encounter is that the joint between the corner panel and the next one back (right under the headlight) is pushed in a bit and the joint came unconnected. I can see the joint tabs in the opening.
    Anyone here have any experience popping this joint back together? I searched, but found nothing in the archives about this. I expect that using a hair dryer to warm up the plastic might make it easier to bend the tab(s)so they will go back together, but I am looking for advice.
    Thanks for any comments/suggestions, but not looking for flames, as my flameproof "johns" are at the cleaners after the scare that dog gave us!
    Phil
    51,838
    i can't help, but happy to bump your thread. all the best!(y)
  3. Easy Rider 2
    Easy Rider 2 Senior Member
    1,584
    258
    Ocala, FL
    Ask around your area for reputable independent body shops.
    My daughter in Atlanta had a similar problem with her last Toyota.
    The dealer quoted her $1300 for a new fender.
    The body shop fixed it in about 15 minutes and only charged $50.
  4. Phil_in_CA
    Central California
    Thanks, ER2... will check into that.
  5. garglo
    garglo Member
    99
    45
    Port St Lucie, FL
    2020 Prius Prime
    Sounds like what happened to my rear bumper. I just pulled the bottom out and pushed the tabs in. Pushed hard with my knee and it snapped into place.
