2010 - Sudden 12V Battery Failure
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by jdcollins5, Jan 25, 2015.
  1. Easy Rider 2
    Easy Rider 2 Senior Member
    1,584
    257
    Ocala, FL
    Yes slightly.
    Simply leaving it connected longer will make up for all but the most drastic low temps.
    And when you take it back out in the cold again, the available capacity goes down as it gets cold again any way.
    I guess I'm gonna have to look at the BatteryMInder just out of curiosity; later, don't have much time right now.
    I recently got a 2/10/50 Cen-tech charger from Harbor Freight because........the price was right (cheap).
    I am testing it now on my Fusion Hybrid and after only about 20 minutes there are some interesting, but not surprising, results.
    I didn't even notice that it has a "regular/AGM" switch but preliminary indications are that it does NOTHING.
    It also has a light that turns green when "fully charged" but it show green on the 2 amp range but not the 10 one.
    More later but it sure looks like just a plain old manual charger to me but I figured that going in.
    #81 Easy Rider 2, Jan 31, 2015
  2. StarCaller
    StarCaller Senior Member
    1,247
    698
    Cedar Crest, NM, USA
    interested in what you're going to figurev out here; especially the 'regular/agm' thing/
  3. lar.smith42
    lar.smith42 Active Member
    203
    118
    Double Oak , Texas
    I don't think that is a good idea because batteries give off fumes when being charged. If you need to bring your battery in the
    house to charge it its time to buy a new one!!
  4. rifis
    rifis Junior Member
    I
    IF a charger accurately measured battery temperature, AND adjusted charging voltage accordingly (for instance: at 32F, charging voltage was upped 0.6v), would not that charger be EQUALLY effective out in the cold?
  5. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,338
    Wilmington, NC
    Well I did the parasitic drain test, and like Mendel, after some time and everything finally goes to sleep I read 16mA. It would jump up to about 40mA every now and then but mostly held the 16mA.
    So I put my analog 2/10A charger back on to try to fully charge it. After about 3 hours the meter was down to zero amps and about 14.2V. I decided to just leave it on the charger a little longer and continue to check it.
    Mendel I checked my wife's Accord with a 3 year old Honda 100 month battery. It read 12.45V at about 40F.
    I would think the answer to your question is yes. The BatteryMinder that I ordered has a temperature sensor and says that it compensates for temperature by adjusting charger voltage.
    #85 jdcollins5, Jan 31, 2015
  6. lar.smith42
    203
    118
    Double Oak , Texas
    I'm not sure I understand whats going on here. I lived for 55 years in Erie ,Pa where the winters were very cold and in Texas for the last 17 years where it is very hat. My batteries have always lasted for 4 or 5 years with out having to charge them all the time. If you have to charge them its time for a new one. Once they don't hold a charge it's time for a new one. If you have to use jumpers or charge it to turn over the ICE it,s time to go buy a new one. The exception would be if you let the car set for a extended period. In that case i would disconnect the battery
  7. jdcollins5
    5,131
    1,338
    Wilmington, NC
    The Prius battery is different than the ones you have had for the last 55 years. It does not have to start the engine so is a smaller battery. Also being inside the vehicle it is Absorbed Glass Mat rather than wet cell lead acid and vents any gases outside of the car.
    On "non-hybrid" vehicles the starter dragging is typically your first sign of a failing battery. On the Prius, since it only pulls in relays to connect the HV Battery and powers up the ECU's, there is typically no such warning. When the voltage drops much below 12V it can cause a multitude of random warning and fault messages. It can also leave you stranded with no prior warning.
    So if you want to be proactive and not get stranded you do a better job of maintaining these batteries than your typical car battery.
  8. Jonny Zero
    Jonny Zero Giggidy
    1,388
    351
    Austin, TX
    Toyota should create a code and warning message: check 12V battery. It would warn me about a low key fob battery but not the 12V?
  9. lar.smith42
    203
    118
    Double Oak , Texas
    I understand the battery is different. I still maintain that if it doesn't hold a charge you need to replace it or it will leave you stranded. My battery in my 2010 Prius is the original battery and I have never had to charge it. I'm getting ready to change it now because of its age.
    pjksr02 likes this.
  10. rifis
    rifis Junior Member
    I
    I don't believe anyone is disagreeing with this statement.
    But not everyone would agree with this blanket threshold for buying a new one. Though it may be applicable for your particular auto use pattern.
    jdcollins5 likes this.
  11. ETP
    2,802
    1,170
    Auburdale FL
    If your battery has past 4 years have a plan for someone to come and get you and have your vehicle towed. Been there done that and wore that greasy shirt. The $200 that the dealer charges is good insurance plus you can get it done when you are off work and not on the way to work. Like to be dead in the water at 0400 AM on the way to work in the middle of no where. Granted once you get it started you might be ok.
    IMHO have brakes that work, good tires, a full tank of gas, emergency supplies and tools in the car, and a battery in top notch condition.
    I know you youngsters like to live on the edge. Unfortunately I have fallen off the edge and can't get up. LOL:):D
    lar.smith42, frodoz737 and jdcollins5 like this.
  12. jdcollins5
    5,131
    1,338
    Wilmington, NC
    No one is disagreeing with your statement here. If you change your battery before it fails or after the first time you have a deep discharge then you should not have any problems with having to charge and maintain.
    Like you my battery was the original OEM, 5.5 years old, and I had never had an issue with it and never had to charge it. I have a Scan Gauge and could monitor the battery volts without having to hook up a voltmeter. I checked the voltage on a regular basis and with a 52 mile RT daily commute considered that the battery was being charged sufficiently each day.
    My problem was that I went beyond the recommended 4 years due to a false sense of security. My car died after driving to church a couple of Sundays ago and I had no idea I had a battery problem until I turned the car off and tried to lock the doors. Fortunately for me I could catch a ride home, get my other car and my tools and jump the car. Others have not been so fortunate. I am really glad that I was driving and not my wife.
    This is the reason that I started this thread. Maybe this will help prevent others being stranded before replacing their batteries. My dealer Parts Manager said that his experience with the original OEM batteries is about 4 years.
    Others on here have recommended fully charging the replacement batteries before installing. Now I fully understand why. There are also automatic battery chargers that can help maintain the battery at full charge to help increase the life of the battery.
    #92 jdcollins5, Feb 1, 2015
  13. rifis
    rifis Junior Member
    I
    I erred. "Trigger, not "threshold".
  14. Den49
    Den49 Member
    498
    268
    Maryland
    When my wife and I both worked and each had a daily 25 to 30 mile one way commute, our car's 12V batteries stay charged from daily driving and needed no supplemental charging. Now that we are both retired, our cars sit more days than they are driven. The Prius is driven only on short local trips and the Avalon gets a few long trips per year. So now their batteries need to be hooked up to a charger/maintainer to maintain their charge level and lifespan. So it really depends on how you drive as to whether you need to supplement the charging of your battery. In any case, after four to five years, you have gotten nearly all the life out of a modern battery and are living on the edge of being stranded. At this point, there is apparently no aftermarket direct replacement for the 57Ah Panasonic AGM battery in my Avalon and the dealer cost for a replacement is around $320.00.
    #94 Den49, Feb 1, 2015
  15. GregP507
    GregP507 Senior Member
    3,002
    480
    I used to help raise cattle when I was growing up, and one way to guarantee yourself a lot of extra trouble with birthing calves, is to "do too much" by hovering around a birthing cow when she's in labor. The trick is to leave well enough alone, and intervene only when necessary. People who micromanaged the process too much, had excessive veterinary bills and high mortality rates.
    I believe the same philosophy applies somewhat to a lead-acid battery. Obsessing with it too much, giving it booster charges when it doesn't need it, only shortens it's life. It can also be quite messy and even dangerous.
    The Electric Me likes this.
  16. Easy Rider 2
    1,584
    257
    Ocala, FL
    Please understand that my findings apply ONLY to this particular (cheap) charger but so far I have not found any situation in which the AGM switch make any difference it the charging voltage.
    I first tried it on both the 2 and 10 amp charging ranges while the battery was down a bit and actively charging; switching the AGM switch made ZERO difference in the charging voltage.
    After being connected for a few hours on 2, the "float" voltage was 12.8 and the green light was on with both 2 and 10 settings.
    Since 12.8 is not really high enough a float voltage for any auto battery, it appears that something actually switches off when the green light comes on. That was a pleasant surprise. At that point, however, the AGM switch still did nothing on either charging range.
    My conclusion: While some more expensive chargers might actually do something slightly different when an AGM switch is operated, this one doesn't.
    AND......I still contend that you don't NEED a different setting for AGM batteries. It is fairly easy to design one that hits a happy median and will adequately charge both flooded cell and AGM just fine.
    From the charts that have been provided lately, I now see why charging a GEL battery can be a little trickier as it requires LOWER voltages.
    Putting a GEL battery in an older bike with charging voltages up around 15 might be a big waste of money.
    Not true for a sealed AGM......unless you do something stupid they give off ZERO emissions.
    That is a bad idea for several reasons.
    A proper battery "tender" is a much better solution.
    But there is a big difference between not "holding" a charge and not being used in a manner to ever achieve a full charge over time.
    ALL lead-acid batteries self-discharge when not actively in use, AGM types much less.
    ALL of them are also damaged by being left in a discharged state.
    These are simple concepts; don't try to make it more complicated than it IS.
    Just because your usage patterns are not hard on the battery does not mean that nobody's IS.
    Done right, none of that is true.
  17. GregP507
    3,002
    480
    Question for the masterminds out there: if you lowered the system voltage by say, 1 volt, would the battery last longer?
  18. Easy Rider 2
    1,584
    257
    Ocala, FL
    What exactly is "system voltage" ??
    The likely answer is NO.
  19. GregP507
    3,002
    480
    You missed the part about being there constantly, micromanaging it, "doing it right."
    The whole point is that few of us can afford the time to be there all the time, to "do it right."
    OK, I'll speak slowly, if the charging circuit maintains the system at 14.4 volts, would lowering it to 13.4 volts make the battery last longer?
  20. Easy Rider 2
    1,584
    257
    Ocala, FL
    Yes. That is why modern charging system DO drop the voltage down to about that level if and when the battery reaches a full charge.
    And that is charging voltage, not "system voltage".
    When the battery needs a charge, an extra 1 volt is not a bad thing.
    As to your other point, I agree with your general contention that obsessing over things can be a bad thing but taking 30 seconds to connect a battery tender when you know the vehicle will not be (or has not beeen) used for a while is hardly an onerous task.
