Map light/ Dome light bulb replacement.
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Caleb302105, Jan 21, 2015.
  1. Caleb302105
    Caleb302105 Junior Member
    29
    Bend, OR
    Hello,
    I wanted to replace the bulbs in my map light but ran into some problems. I was able to remove the first see-through plastic cover on the light. Also I was able to twist one of the bulbs out of the socket so it was loose but there didn't seem to be a way to pull the bulbs out of their metal holders. I tried with medium to light pressure on the right side bulb and it slipped from my fingers and jumped back into the area on the other side of the metal holders. Now I can't see it or reach it. What do I need to remove to retrieve the bulb and how do I remove it? I can't seem to find anything on Prius chat or elsewhere showing anybody changing these bulbs.
    Thank you for your replies.
  2. PriusGuy32
    1,417
    514
    Harrison Township, Michigan
    Uhhhh I just pulled the bulb straight out, no need to twist anything.
    Also, I'd strongly recommend replacing with LED bulbs - I just bought a kit for my whole interior on eBay for $12.99 and am VERY satisfied. Here's the link:
    http://pages.ebay.com/link/?nav=item.view&alt=web&id=251579449514
    11 x White LED Light Interior Package Deal Kit Map For 2004 - 2014 Toyota Prius
  3. Sergiospl
    Sergiospl Senior Member
    3,938
    1,351
    28
  4. dpeverhart
    dpeverhart Member
    126
    I
    Ditto on the LED light kit. I got the same one and it's really nice.
    PriusGuy32 likes this.
  5. Caleb302105
    29
    Bend, OR
    Alright, so don't laugh but I went back out to the car and the light came on (figuratively speaking). Unfortunately, now I realize that I actually untwisted the whole socket and the bulb and they both are what went back up inside. Oops... :-(
    Do you have any idea how I could get back behind there and retrieve the lost bulb and socket?
    Okay, so now using a diagram from the service manual I found out that in order to remove the whole unit I had to take two screws out and then carefully un-snap all 4 pins by gently pulling down on each end of the unit.
    I found the missing socket and the bulb.
    Thank you everyone for your insight on the matter.
    P.S. The LED stuff sounds awesome. I'll have to check it out.
    #5 Caleb302105, Jan 21, 2015
  6. CooCooCaChoo
    CooCooCaChoo Senior Member
    958
    535
    Cow-lee-fornia
    2023 Prius
    I jiggled mine back and forth and from side to side in order to loosen it.
  7. Kate Harvest
    Kate Harvest Member
    105
    Vancouver, WA
    I just did exactly the same thing as you putting in my new LED's. Thanks for the tip about the two screws -- managed to fetch my old bulb and socket that way! :)
