Best tires for the Prius?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by gqscientist, Jun 12, 2007.
  1. jaqueh
    jaqueh Active Member
    341
    199
    San Francisco
    Would you guys say that the A/S or the Defenders have better handling characteristics?
  2. Scallywag
    Scallywag Member
    107
    22
    Columbus, OH
    I haven't actually driven the Energy Savers. The Defenders are rated higher for handling though, and I've previously described them as the best-handling tires I've ever owned.
    Hopefully someone who has driven both can reply.
  3. lar.smith42
    lar.smith42 Active Member
    203
    118
    Double Oak , Texas
    This may not help but I had defenders on my Honda CRV. Hated them. No wet traction and rough ride. I have 195/65-15 Yokohama AVID Ascend tires on my 2010 Prius and love them. Good handling, quiet ride, and good traction. ( 51 PSI max on side wall )
    ETP likes this.
  4. SWprius08
    SWprius08 SoCalprius
    170
    Los Angeles (SFV)
    Defenders are rated 44 psi max which is the same as oem tires. I have not used energy savers as well, defender only and I like its handling, perhaps you can install one and use those 30 days then return and use another for 30 days and decide. let us know too what ypu find
  5. Okinawa
    Okinawa Senior Member
    1,333
    320
    I had a 2011 Prius Two. I had Michelin Defenders on it. The handling was great. It had a quiet comfortable ride. Has a 90,000 mile tread wear warranty. That was my experience with the Defenders.
  6. spidey
    spidey Junior Member
    81
    central north carolina
    I just tried to price defenders at Sears and the web site says they do not fit a Prius 2009. What size defenders are you guys getting?
  7. Okinawa
    1,333
    320
    Here is a suggestion. Call the Michelin Company at 800-847-3435 and talk to their customer service person and ask them about their tire recommendation for your car. I always do that.
  8. lar.smith42
    203
    118
    Double Oak , Texas
    I don't think the Defenders are a LRR tire. That may be why the web says they do not fit.
  9. Xterra72
    Xterra72 Senior Member
    1,437
    1,681
    Have to purchase 4 tires. What to get in 215 45 17.
    Toyota dealership is having a special. They don't carry the favorites like the Bridgestone Ecopia EP422 plus.
    My options are
    Yokohama Avid Envigor (87W- 45k)
    Or
    Michelin Primacy MXM4 (87V- 55k)
    Price difference for a set of 4 us about $185.
    Any opinions? Worth to spend the extra money on the Michelins?
  10. navguy12
    navguy12 Member
    193
    32
    Batawa Ontario
    I installed a set of Michelin Premiers A/S (205/55R16s) 18 months ago. Love 'em........
  11. Xterra72
    1,437
    1,681
    My options are
    Or
  12. kinglew
    kinglew Member
    318
    49
    ny
    2020 Prius Prime
    They are
  13. Mendel Leisk
    41,867
    The Defenders may be in the LRR category, but definitely not in the same league as something like the Energy Saver A/S, or for that matter Bridgestone Ecopia (EP20 or EP422). Michelin website rates all their tires for "fuel economy", puts the Energy Saver A/S at 10 (out of 10) and the Defenders at 8.. For reference, the Premier A/S are rated 9 and Michelin Pilot HX MXM4 are 7.
    Just to be contrarian, our 17" rims came with the Pilots, and they seem to roll quite easy, lol.
    ETP likes this.
  14. kinglew
    kinglew Member
    318
    49
    ny
    2020 Prius Prime
    Check Nov issue consumer reports defender top pick see for yourself !!​
    #214 kinglew, Oct 9, 2015
    ETP likes this.
  15. Xterra72
    1,437
    1,681
    I am replacing my Toyo Proxes that are currently at 46,500 miles.
    I went to my local Costco and purchased Michelin Premier A/S 215x45x17
    Costco expedited order. Will be installed soon.
    I paid $606 (out the door )
    #215 Xterra72, Oct 9, 2015
    ETP likes this.
  16. Mendel Leisk
    41,867
    I'd be interested to hear how those work for you, thanks. We've got Michelin Pilot HX MXM4 in that size right now, sooner or later will need to replace.
    ETP likes this.
  17. ETP
    2,803
    1,170
    Auburdale FL
    Good info folks. Think a long time before straying from that marriage with your OEM/MIJs. The next wife may be worse.
    #217 ETP, Jul 3, 2016
  18. bisco
    52,354
    exactly. as much as i would like a quieter ride, i'm considering new goodyear assurance.
    ETP likes this.
  19. bisco
    52,354
    consumer reports doesn't care about your mpg's, but yes. the defenders are a great tyre for many applications.
    ETP likes this.
  20. PaulRivers
    PaulRivers Member
    104
    MN
    The Gen II Prius OEM tires were awful terrible tires in almost every way.
    Recommending a Gen II Prius owner stick with the OEM tires is a terrible suggestion.
    I switched from the stock tires to the Defenders around 50,000 miles ago. After the breakin period my mileage went up slightly. Everything else improved noticeably - much quieter, better handling, better stopping distance in bad weather conditions, better grip in the winter (not amazing but better), less noise from the tires. My only complaint is that after about 50,000 miles the front tires have worn out and they were supposed to last 80,000 but the rear tires are in amazing shape, so perhaps it will average out at 80,000 between the front and rear tires.
    But having used both I can not imagine suggesting to anyone to stick with the original OEM tires on the 2nd gen prius.
