The Retrofit Source HID 5500k or 6000k?..
Discussion in 'Gen 3 Prius Accessories and Modifications' started by Xterra72, Feb 2, 2015.
  1. Xterra72
    Xterra72 Senior Member
    1,429
    1,673
    To match the led parking light, drl and fog lights?
    The Retrofit Source 5500k I currently have on my low beam definitely does not match. i guess with a 35w ballast, the light output is not as intense.
    #1 Xterra72, Feb 2, 2015
  2. Harris_BRG
    Harris_BRG Junior Member
    40
    Houston
    I use 6k in all my cars, but it has a very slight blueish hue. So I'd recommend if you want to match the white light emitting to choose 5k.
  3. Xterra72
    1,429
    1,673
    Just checked my HID. They are actually H11 XB35 5500k. I guess I will have to go with the 6000k.
    I guess with the 35w ballast the output is not quite white or maybe with it next to my leds, it doesn't look white enough.
  4. sfprankster
    sfprankster Active Member
    444
    490
    Santa Cruz Mountains, CA
    Going up in numbers, 5.5k --> 6k, gets you closer to the blue end of the spectrum. Less white light and a more bluish hue.
    adizon likes this.
  5. Xterra72
    1,429
    1,673
    Yeah. I know if I went from a 35w ballast to a 55w ballast the lumen output goes up by 20% but lessens the longevity of the bulb. If I had the 55w ballast, I think the 55000k would have been a better match with my leds.
  6. sfprankster
    444
    490
    I'm only referencing the color spectrum numbers(i.e. 4k, 5k 6k), not the wattage output.
    Lumens are the measurement for the brightness of the bulb's output, not the color spectrum.
    The lower color spectrum numbers run into the yellows(3k-4.5k), whites are closer to 5k, and above 5k, the blues(6k-8k) enter the into spectrum.
    As you get higher into the color spectrum(6k+), there is less usable light. You'll really notice this near dusk on a wet, rainy road. It gets very difficult to see the differences of the road surface.
    #6 sfprankster, Feb 2, 2015
    Xterra72 likes this.
  7. Xterra72
    1,429
    1,673
    Maybe I will just stay with what I have considering the less usable light of the 6k.
  8. sfprankster
    444
    490
    or try a 5k maybe, or even as low as 4.3k.
    Lower than that and the yellow really begins to show.
    Aren't you in the SF Bay Area?
    Swing by ExtremeHID on Tully Rd in San Jose. They're right off 101. They have a display with HID lights ranging from 3k to 8k, where you can see the difference.
  9. Harris_BRG
    40
    Houston
    I would check out DDM Tuning online. Pretty cheap Hid kits from Japan, but really good quality. They offer the 55watt ballasts.
    so 5k with the 55watt would look good.
  10. Xterra72
    1,429
    1,673
    I currently have the morimoto HID 35w ballast with the H11 XB35 5500k installed in my car.
    Even though it's not an exact match to the leds I have installed in the parking lights, fog lights and drls, I think I will keep my current setup.
    SAFETY is way more important to me than trying to match the light output to a "T".:D
  11. slowpriusj
    slowpriusj Active Member
    167
    271
    Brunswick, MD
    I took 4500k only because I like the color flicker you get with the yellow/white hue
    :cool:
  12. pauerbach
    pauerbach Member
    101
    34
    Color flicker? That sounds seizure-inducing.
  13. slowpriusj
    167
    271
    Brunswick, MD
    You can't see it when you drive only when people go by! looks awesome
  14. katiesdad7
    katiesdad7 Member
    172
    25
    Stuart, FL
    I went with the 5K and love it. I did have to adjust the aim but its real easy.
