Traction Battery Longevity
Discussion in 'Generation 1 Prius Discussion' started by giannoni, Feb 4, 2015.
  1. giannoni
    giannoni Junior Member
    Northport, NY, USA
    2001 Prius
    I have a 2001 with 60K miles used in the NE USA and apparently running normally. At 14 years, I'm concerned about the ongoing condition of the battery. Any help & info greatly appreciated & thanks!
  2. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
  3. bisco
    52,269
    pick up a grid charger at the priuschat shoppe, your car will last forever! (almost:))
  4. messenger
    messenger Junior Member
    30
    Fairfield, IA USA
    Here's a good read on testing the current condition of your battery:
    Predictive battery failure analysis for the Prius Hybrid
    Note: I found out by checking my vin number on line that Toyota had replace the battery in my car under warranty in 2009, it tested as new using the above method.
    Tim
