Which wheel hub assembly have you replaced so far?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by TPLOR, Feb 8, 2015.
  1. TPLOR
    TPLOR Junior Member
    My 2005 Prius with 180K miles has the front driver wheel hub assembly replaced already.
    Which ones on your car have you replaced?
    My car is starting to make loud noises again, someone stated that rear hub assembly generally don't get replaced? Can someone confirm this?
    I live in the USA.
  2. sorka
    sorka Active Member
    1,026
    198
    Merced, CA
    2019 Prius
    Mine's at 187K. Still no wheel noises. All original hubs.
  3. Patrick Wong
    18,204
    6,505
    My 2004 has 190K miles, no issues with the wheel bearings.
    However if the OP's car needs new bearings, then it doesn't matter how many other Prius have needed or not needed them. It is certainly possible for a rear wheel bearing to fail and the OP needs to have the noise checked out.
  4. ursle
    ursle Gas miser
    1,049
    192
    NH
    An '06' both fronts at 40-60,000
