  1. Xterra72
    Xterra72 Senior Member
    1,432
    1,679
    So I experimented today. was blaming my cheap tires and the software update on my low mpg.
    Well, it was actually my driving. Instead of flying on the fast lane with the flow of traffic at 65 mph (or higher), I took my lead foot off the accelerator and stayed on the slow lane and kept it steady at 65 mph.
    Temperature outside was at 61 degrees, I had the temp set at 66 degrees at 3 bars, stayed at the speed limit, used the high mpg gliding and accelerating at hill techniques and voila! My mpg went from my low 38-40 mpg to 48 mpg. Awesome!
    Edit: Since this is the mod section I also included my cheap tires setup until I have to replace all 4. Currently the the two toyo proxes I have on the car has about 31,500 miles.
    #6121 Xterra72, Feb 12, 2015
    slowpriusj and Blizzard_Persona like this.
  2. slowpriusj
    slowpriusj Active Member
    167
    271
    Brunswick, MD
    I typically travel 30 miles round trip.
    ^ I really didn't buy this car to get 50 MPG (although that would be nice), I bought it because it was really affordable but thats beside the point, I haven't gotten over 40 MPG when driven stock. I have to admit I travel 70-75 MPH on my commute but it's all consistant. Once I change the oil, do an alignment, maybe change spark plugs, cover lower grill, and whatever else you guys recommend I can hopefully report better news. Like I mentioned, when I slammed it, it was returning 2 MPG better??? But thanks for the kind words, I only copied what some other people did on here lol! Gotta love the forums, and more pics will be coming soon!
    Ramtart likes this.
  3. Blizzard_Persona
    1,787
    946
    Pa.
    2023 Prius Prime
    XSE
    Slowpriusj, 70-75mph is not helping at all. FYI. Try 60mph on cc and report back.
    55 if you can is even better.
    Xterra72, see slowing down does work ;)
    Now try 55-60 and be amazed. Lol.
    ^^^^ this should bump up your mpg at least a few for starters.
  4. slowpriusj
    167
    271
    Brunswick, MD
    ^^^ I may have to live with my 33-34 MPG lol:LOL:! J/K, I have to fill up tomorrow so I will TRY to keep it at those speeds! TRY...
  5. Xterra72
    1,432
    1,679
    55-60 on our 280 freeway? wish I could do that but bay area traffic especially on this freeway is suicide.:D
    Maybe on an expressway. Hehe:D
  6. Blizzard_Persona
    1,787
    946
    Pa.
    2023 Prius Prime
    XSE
    I drive 55 on I95 in an around Philthadelphia w/o issue....mind you we won the prestigious award of the countries worst drivers last yr. lol.
    55 is Unless I'm on my FZ-1 which can do 80 in first gear. Lol. Then all bets are off.
    The folks blowing by me going 90 are just gonna get stuck in the next set of gridlock a couple mins before me :)
    They call the I76 the worlds largest parking lot for good reason. HAHAHAHAHAHA!!!
    #6126 Blizzard_Persona, Feb 12, 2015
  7. Xterra72
    1,432
    1,679
    70-75 mph will definitely get you below 40mpg. My commute is 100 miles round trip. I was averaging about 38 mpg until today when I went on the slow lane and drove at the 65mph limit. My mpg went back up at 48 mpg. Huge difference. Only problem is, it took me longer to get to work. I guess it's better than getting a speeding ticket.:D
    adizon likes this.
  8. Blizzard_Persona
    1,787
    946
    Pa.
    2023 Prius Prime
    XSE
    Xterra72, time your drive at that different speed, my bet is you only lose 10 mins or so. :)
    Xterra72 likes this.
  9. slowpriusj
    167
    271
    Brunswick, MD
    Cool I will try it! Gonna try to put some more pics up tonight, photo bucket does not work at work.
  10. sfprankster
    sfprankster Active Member
    444
    490
    Santa Cruz Mountains, CA
    Big box arrived from Japan...
    My black/beige custom seat covers from Clazzio... :D
    Took 3-4 minutes to install...
    ...a single headrest cover. :rolleyes:
    And they said it could take 10-14 weeks to produce and ship(ordered them on Jan 16). (y)
    slowpriusj likes this.
  11. Blizzard_Persona
    1,787
    946
    Pa.
    2023 Prius Prime
    XSE
    Here is my commute into work today in my Persona. Temp was mid 30's and dropping fast, I only used front defroster for a couple mins when I first left my house then I shut it off for the rest of the drive. 55mph as long as I could on the highway then I hit heavy traffic. I am quite happy with these numbers. :) See what 55 mph can result in.
    slowpriusj and Xterra72 like this.
  12. slowpriusj
    167
    271
    Brunswick, MD
    Can't wait see this!
  13. slowpriusj
    167
    271
    Brunswick, MD
    As requested! I am not photogenic as you can see :notworthy:
    I may need some spacers in the rear and then it will be flush but front is perfect!
    Johnsk93, TopRamen, Burna J and 2 others like this.
  14. sfv41901
    sfv41901 Masta S
    4,591
    5,293
    Palmdale, Ca
    Yesterday, I needed a tow to the dealer.
    "Check Hybrid System" showed up on the DIC. Dramatic loss in power then it went out of ready.
    Today the dealer said there was an issue with the inverter pump so they reset the codes & drove 60 miles with no problem
  15. Xterra72
    1,432
    1,679
    Hope everything is ok. Keep us up to date.
  16. nivlac915
    nivlac915 Member
    77
    56
    up in the hills of covina, west side
    met up with sean (sfv41901) early this morning to install these. might not be the G's but it will do.... for now. thanx again and great meeting you sean!!
    Also want to thank andy (ac320) for the headlights as well!!
    #6136 nivlac915, Feb 13, 2015
    Johnsk93, ac320, Burna J and 4 others like this.
  17. Accordlayingkit
    Accordlayingkit Senior Member
    1,616
    1,747
    377
    Colonial Heights, Va
    They jus jdm or what?
  18. sfv41901
    sfv41901 Masta S
    4,591
    5,293
    Palmdale, Ca
    They are JDM halogen headlights.
    Accordlayingkit likes this.
  19. sfv41901
    sfv41901 Masta S
    4,591
    5,293
    Palmdale, Ca
    Great meeting u @nivlac915
    Here is a pic I took
    adizon, Johnsk93, Xterra72 and 4 others like this.
  20. Burna J
    1,068
    3,337
    53
    Long Beach, CA.
    Looks great Bro, nice score... (y)
    sfv41901 and nivlac915 like this.
