One very good reason to carry the physical key with you.
Discussion in 'Gen 3 Prius Main Forum' started by GregP507, Feb 12, 2015.
  1. GregP507
    GregP507 Senior Member
    3,002
    481
    This has happened twice since I bought the car. The SmartKey system is great most of the time; you simply grab the handle and it unlocks. However, if the seat-belt buckle gets caught in the door, it can get caught on the first latch, where the door becomes locked and unlocked at the same time. You can't bump the door shut because of the buckle, and you can't open the door because the smart-key won't activate because the system thinks the door is open.
    So there you are; your door is caught on the first latch, and you can't open or close your door. The only remedy is to pull out your physical key and use it to unlock the door.
    52,390
    huh, that's not happened to me in 10 years.(n)
  3. GregP507
    3,002
    481
    I see, that means it never happens.
  4. bisco
    52,390
    well, even though i've never removed the key from the fob, that's certainly no reason to take the metal key out of the fob and leave it home, is it?
  5. GregP507
    3,002
    481
    I don't know about 10 years ago, but I got two fobs, with a key in only one of them.
  6. bisco
    52,390
    what????? now i have to go look.:eek:
  7. bisco
    52,390
    i got two identical with a key in each. did you buy used? i never knew they made a keyless fob.
    retired4999 likes this.
  8. GregP507
    3,002
    481
    That's what I got.
  9. bisco
    52,390
    interesting. maybe a chinese knock off.
  10. GregP507
    3,002
    481
    I made sure to put the keyed one on my key-chain.
  11. bisco
    52,390
    well done.(y)
  12. Redpoint5
    Redpoint5 Senior Member
    1,026
    509
    Portland, OR
    In a tangent story, I locked myself out of the house the other night and slept in the Prius.
    I hadn't transferred the house key to the Prius key chain, and as I left the house I used a remote transmitter to close the garage door. Well, I left the air compressor turned on, and it tripped the circuit breaker the door opener is connected to.
    It took me 45 minutes in a downpour to snag the garage door release lever using a coat hanger.
    That reminds me, the key I was given with the car doesn't work. The SKS was from a different car, so it has a different physical key. I'm still waiting for my mini VCI cable to arrive so I can program back the original fobs with working keys.
  13. bisco
    52,390
    i keep a house key hidden under the door mat.
  14. Redpoint5
    1,026
    509
    Portland, OR
    I keep a second story window unlocked, but the wife must have locked it. Getting up there without ripping the gutter off was difficult, and jumping off the roof even harder.
  15. bisco
    52,390
    you did say you were a risk taker...:p
  16. Blizzard_Persona
    1,787
    948
    Pa.
    2023 Prius Prime
    XSE
    I gave my neighbor a spare key, easier knocking on thier door than scaling my house like Spider-Man. Lol.
    If thier not home guess I'm sol, unless I can get to my parents who have an extra key...
  17. macman408
    1,179
    368
    One of my friends once scaled balconies on the outside of his building to get to his 11th-floor apartment, where he knew his balcony door was open. Apparently that was the easier option rather than going to see his roommate at work to borrow his key, a 15-minute walk away.
    He is a very special individual. (The same guy also returned to playing Ultimate Frisbee the day after having knee surgery, which he required on both knees by his early 20s likely because he played so much Ultimate.)
    But I digress.
    Just to justify my random storytime, I'll chime in that my car also came with 2 identical fobs, both with metal keys. An interesting tip, however.
    Redpoint5 likes this.
  18. mrbigh
    3,686
    699
    Long Island, NY
    With my current PiP and also the 4 former Prii we owned since 2005, all of them came with 2 fobs with metal keys as part of it.
  19. GregP507
    3,002
    481
    Never forget to prepare for the "what-ifs."
  20. DoubleDAZ
    DoubleDAZ Senior Member
    1,209
    322
    Peoria AZ (Phoenix)
    You'd think one of the other doors or the hatchback would have opened.
