Have you ever unknowingly driven in "B" gear?
Discussion in 'Gen 2 Prius Main Forum' started by Vespasian, Apr 9, 2006.
  1. Vespasian
    Vespasian New Member
    126
    Illinois
    I did the other day for about 10 miles until I realized that something about the car didn't feel right. Why I didn't realize sooner, however, is beyond me. :unsure:
  2. rdenneyutmb
    rdenneyutmb New Member
    31
    <div class='quotetop'>QUOTE(Vespasian @ Apr 9 2006, 06:43 PM) [snapback]237271[/snapback]</div>
    Yes, this happens. It is rather easy to bump the shift lever without realizing it. Car doesn't glide in B...
  3. the fish
    the fish Member
    175
  4. Tideland Prius
    16,559
    Yeah when I switch to B and forget to switch back. The most telltale sign is when your engine doesn't shut off at the light and "stutters".
  5. jeneric
    jeneric New Member
    442
    Redmond, WA
    I don't know...
  6. efusco
    efusco Moderator Emeritus
    19,891
    1,196
    Nixa, MO
    Back in my rebellious 'experiementing' days I tinkered with B-mode for slowing to a stop. Occasionally I'd take off forgetting to switch back to drive. But I always knew something was wrong the first time I backed my foot off of the accelerator b/c the car slowed so much faster than usual. Few moments of confusion and I'd figure it out.
    Now that I never use B-mode it hasn't happened.
  7. highroute
    highroute New Member
    94
    Oakland CA USA
    <div class='quotetop'>QUOTE(Tideland Prius @ Apr 9 2006, 05:16 PM) [snapback]237294[/snapback]</div>
    I noticed that cruise control wouldn't work.
  8. Vespasian
    126
    Illinois
    <div class='quotetop'>QUOTE(Tideland Prius @ Apr 9 2006, 09:16 PM) [snapback]237294[/snapback]</div>
    That's why I don't understand why it took me so long to figure out I was in the wrong gear. My mind must have been elsewhere.
  9. qbee42
    3,079
    <div class='quotetop'>QUOTE(rdenneyutmb @ Apr 9 2006, 07:50 PM) [snapback]237274[/snapback]</div>
    Newbie question (my Prius is supposed to be delivered this week!): How do you shift out of B? I'm guessing you flip the joystick down to D. Is that correct?
    Thanks,
  10. highroute
    94
    Oakland CA USA
    <div class='quotetop'>QUOTE(qbee42 @ Apr 10 2006, 07:01 AM) [snapback]237460[/snapback]</div>
    To go to D, you flip the joystick to the left and down. (Straight down is B.)
  11. faastguy
    faastguy Junior Member
    Lake Tahoe
    Correct! Just move the joystick back to D. Just make certain you don't mistakenly shift into R, or the tranny shifts into N :eek:
  12. jamarimutt
    jamarimutt New Member
    985
    In a regular car, if you take off in low gear you'll notice it quickly because of the sound of the engine. In the Prius, accelerating in B feels the same as accelerating in D, you notice the difference, as efusco said, when you remove the foot from the gas pedal.
