Prius in the wind
Discussion in 'Gen 3 Prius Main Forum' started by southjerseycraig, Feb 14, 2015.
  1. southjerseycraig
    southjerseycraig Active Member
    438
    107
    Cherry Hill, NJ
    I am thinking of visiting my girlfriend 60 miles away. Heavy winds are predicted over Saturday night and into Sunday morning -- perhaps about 30 mph with gusts up to 55. How does the Gen III (2010, II) handle in the wind? Am I going to be blown all over the road?
    Thanks!
  2. magnumrtawd
    magnumrtawd Member
    306
    72
    Toledo,Ohio
    You. Betcha !!!!
  3. WolfpackBill
    WolfpackBill Senior Member
    349
    500
    Lexington, NC
    Sure does. Wonder if there's anything we can do make it less susceptible to crosswinds.
  4. Starbrand
    Starbrand Senior Member
    493
    1,503
    Westmont, IL
    60 miles ain't bad (estimate 2hrs). had that wind yesterday after work; would feel the shake above 65mph. you should be fine below that.
  5. Blizzard_Persona
    1,787
    947
    Pa.
    2023 Prius Prime
    XSE
    Ill be leaving for work in a few Hrs and I'll let you know how it goes...
  6. A617
    A617 Member
    213
    95
    OKC, OK
    A truck or suv passing by you at 45 mph at a stop light is enough to rock the car a bit.
  7. Blizzard_Persona
    1,787
    947
    Pa.
    2023 Prius Prime
    XSE
    Is it snowing in Cherry Hill yet?
    There is already more snow on the ground over the bridge here on the PA side that a couple weeks back during the "SNOWPOCALYPSE", translates to about a half inch coating thus far ;)
  8. southjerseycraig
    438
    107
    Cherry Hill, NJ
    I'm not in Cherry Hill now, but rather up in Flemington, about an hour due north of Trenton. (As you can see, I am chancing it and doing the visit.) Snow has started in Flemington. I'm not worried as much about the snow as about the winds tomorrow (Sunday) morning when returning to Cherry Hill.
  9. Blizzard_Persona
    1,787
    947
    Pa.
    2023 Prius Prime
    XSE
    I think we will be fine. Just take it slow and steady.
    This ain't Wyoming where semi's get blown of the highway.
  10. Blizzard_Persona
    1,787
    947
    Pa.
    2023 Prius Prime
    XSE
    Well just checking in....
    I made it home without incident. I just took it real slow (45 mph on I95).
    Had some co workers worried about the platt bridge but honestly it wasn't bad. Yeah the winds are stupid right now but as long as your driving slow enough to dodge the trash cans blowing down the streets you should be fine.
    My Prius never felt out of control or like I couldn't stay in my lane. Oh and no issues with the couple inches of snow on the ground with the stock persona tires, granted the highway was salted but half the drive had a coating of the white stuff.
    Good luck and be safe brother. Did you get home yet or making your drive home Tomm?
    ftl likes this.
  11. cyclopathic
    cyclopathic Senior Member
    3,292
    547
    2014 Prius c
    yes, here is the list of what worked for me:
    - bump up pressure difference front/rear (40 vs 36 or 42 vs 36)
    - add rear antisway bar
    - add STB
    - if still not enough, install camber kit and do alignment
    WE0H likes this.
  12. Blizzard_Persona
    1,787
    947
    Pa.
    2023 Prius Prime
    XSE
    Or just drive the car as is.....
    Tande likes this.
  13. defrankond
    defrankond Member
    217
    North Dakota
    I live in nd and the winter months here we have wind always at 30mph+. You will def feel it whopping the car but as far as throwing you over the road like a rag doll is highly unlikely. It is no different than most cars these days with high profiles ie suv, mini vans, trucks, or crossovers. Just go a little slower to make it less noticeable and you will be fine
  14. southjerseycraig
    438
    107
    Cherry Hill, NJ
    I got back home OK. I didn't need to take any bridges. I thought that occasionally the car would pull to one side, but it was not a big deal. Thanks to everyone for their advice.
  15. WE0H
    WE0H Senior Member
    3,247
    528
    Install the TRD rear sway bar and the car will handle much better in the wind. It is fine bone stock, but the TRD suspension parts really make it handle nice.
    Mike
  16. EddieDesigns
    EddieDesigns Junior Member
    78
    42
    Hilliard, OH
    I went from a 2011 Kia Soul+ to my Prius…comparatively, the Prius handles a lot better than the Soul when it's out on the highway.
    Yes, I feel the buffeting/turbulence from crosswind, tailwind, getting caught in the wakes from semi-trailers, but nothing as noticeably pronounced as in the Soul.
    If I had to gauge the Prius' handing as far as it's chart position between a Kia Soul and a Camry (which is our other car), I would say the Prius leans much closer to handling like the Camry…not scientific fact, by any stretch of the imagination, just my subjective perspective.
    So, car nuts, how much does a car's wheelbase have to do with how it handles? I am of the school of thought that the longer and wider a car's stance is, the better it handles…I may be wrong, but at least it sounds good and is a sound concept, at least.
    We're taking our first road trip in the Prius next weekend, to St. Louis, so I'll have a better idea of how its handling compares to the Kia on long trips. I have no doubt it won't be *as* comfortable as the Camry, as long as it's a marked improvement over the Kia, as that was one of the three reasons we traded it for the Prius.
    bt
  17. cyclopathic
    3,292
    547
    2014 Prius c
    Not necessarily; there are some great handling small cars. Longer wheelbase creates stability and compliance on open highway. At expense of handling in tight quarters. And bigger/longer/heavier car needs more engineering go into suspension to make it handle.
    Thanks for letting know of Soul.. Next time I'll get an urge to try hamster car - I'll pass. It is interesting that you find Gen3 handling improvement; for me it was not drivable in stock form.
  18. Blizzard_Persona
    1,787
    947
    Pa.
    2023 Prius Prime
    XSE
    Not only should you get 15 braces and stiffer springs to keep you on the road in a little wind, this new body kit is def. What's needed....
    WE0H and ftl like this.
  19. ftl
    ftl Explicator
    1,812
    790
    Long Island NY
    Nice! But does it come in Blizzard Pearl?
    WE0H likes this.
  20. EddieDesigns
    78
    42
    Hilliard, OH
    I saw that Storm Chaser car and the first thing I thought of was this…a cloaked potentially new Prius…
    Blizzard_Persona likes this.
