Most recent tank
Discussion in 'Gen 3 Prius Fuel Economy' started by wesayso, Jun 2, 2011.
  1. dulcimoo
    dulcimoo Junior Member
    34
    Vista, CA
    5th fill up: Miles to drive reads 551. Total MPG reads: 50.1 Total Computed MPG is 47.4. Last tank computed MPG is 47.25
    Gas price went UP a couple of cents in the past 2 weeks.
    So this is consistent with the car "thinking" that it is getting about 3 MPG more than it is.
    This has got to be some sort of calibration error someplace.
    I drive a lot of hills and freeway miles. So ~47mpg is OK by me.
    Read more: Most recent tank | Page 16 | PriusChat
    Follow us: @PriusChat on Twitter | PriusChat on Facebook
    #321 dulcimoo, Feb 3, 2015
  2. wesayso
    wesayso Member
    385
    35
    Hampton, VA
  3. GregP507
    GregP507 Senior Member
    3,002
    481
    I think mileage is also dependent on the level of charge in the battery. Whether it's depleted or topped-up when you start, it would influence the mileage.
  4. dulcimoo
    34
    Vista, CA
    6th fill up:I got the alert and the blinking. Miles to drive was 15 when I filled up. I put in 9.600 Gal.
    Miles to drive reads 541. Total MPG reads: 50.0 Total Computed MPG is 47.3. Last tank computed MPG is 46.9
    Gas is 2.669 - 41 cents higher in 17 days
    I haven't been driving so much the past few weeks [For 1 and 1/2 weeks I didn't drive at all], and when I did I wasn't trying to drive in an eco friendly fashion. I was "driving" like heck most of the time [that is accelerating quickly and sometimes had to actually use my brakes]. I also needed to use the heater a bit while stuck in traffic.
    Read more: Most recent tank | Page 17 | PriusChat
  5. walter Lee
    1,126
    376
    Maryland
    My ScangaugeII Flv Xgauge which read directly from the Prius' internal fuel tank sensor tops out at 11.4 gallons and bottoms out at .7 gallons. The Prius internal fuel tank sensor readings will vary depending on whether my Prius is going uphill ( higher than normal) downhill (lower than normal) or is on level ground (normal reading). My 2010 Prius low fuel warning alarm rings once when the Scangauge Xgauge FLV reads 1.7 gallons on level ground - but there is a tad more fuel in reality. The 2 gallon of fuel left estimate after the low fuel warning alarm and blinking bar is about right ( I use that tidbit to get 800 miles on one tank of gas) Because its pretty cold now, my Prius' overall MPG is lower than it would be in the summer time. To avoid getting all stressed out from driving - I allot more time to travel. The price of regular E10 gasoline is about $2.20 in the DC Metro Area which is affordable so that makes my wallet happy. Learning to hypermile my Prius - has helped increased my overall MPG almost 20%. Hypermiling isn't always possible but when it is - it can help boost the Prius fuel efficiency.
    #325 walter Lee, Feb 20, 2015
  6. wesayso
    wesayso Member
    385
    35
    Hampton, VA
  7. dulcimoo
    34
    Vista, CA
    7th fill up:
    Total Computed MPG is 46.3. Last tank computed MPG is 47.1 Put in 6.872 Gal
    Gas is 2.749 (Feb 22) [Posting about a week late]
    8th fill up:
    I got the alert and the blinking. Miles to drive was 7 when I filled up. I put in 9.678 Gal.
    Miles to drive reads 531. Total MPG reads: 49.9 Total Computed MPG is 47.3. Last tank computed MPG is 47.8
    Gas is 2.259 - A big jump!
    I turned "eco" mode back on. I seem get about 1 MPG more with it on.
    I could probably go to 600 mi if I go "past" zero (on the "reserve") but it would make me really really uncomfortable.
  8. Mendel Leisk
    40,918
    Good on you for calculating and tracking mileage. But as far as seeking to extend distance between fill ups: pointless, and risky. I'd fill up sooner, say any time you're nearing 1/4 tank remaining.
  9. wesayso
    wesayso Member
    385
    35
    Hampton, VA
    428.4 miles
    9.940 gallons
    $2.219/gallon
    $22.06 total
    43.1 calculated mpg
    45.9 computer mpg on tank.
    $0.0515/mile
    28 mph avg. speed
  10. Xterra72
    Xterra72 Senior Member
    1,432
    1,678
    Here's mine from Northern Cali.
    These results are from 17 inch Persona wheels with a pair of toyo proxes and a pair of cheap non lrr valera tires.
    (y) and the temperature keeps climbing. :D
  11. dulcimoo
    34
    Vista, CA
    9th fill up: (10Mar2015)
    Miles to drive [after fill up] reads 523. Total MPG reads: 49.7 Total Computed MPG is 47.05. Last tank computed MPG is 45.5
    Gas is 3.19/Gal
    MPG is a bit lower due to heater use and more aggressive driving at times.
    10th fill up: (today):
    Last Tank MPG: 48.2 Lifetime MPG 47.2, What the car thinks: 49.7. (2.54 MPG 5.11% high)
    #331 dulcimoo, Mar 15, 2015
  12. dulcimoo
    34
    Vista, CA
    11th fill up: (18Mar2015)
    Miles to drive [after fill up] reads 524. Total MPG reads: 49.8 Lifetime Total Computed MPG is 47.27. Last tank computed MPG is 49.1
    A nice increase!
    Gas is 3.039/Gal
    12th fill up: (10Mar2015):
    What the car thinks: 49.9. Last Tank computed MPG: 48.9 Lifetime total computed MPG 47.42
    I'm getting close to 49 MPG now. Hmm.
  13. wesayso
    wesayso Member
    385
    35
    Hampton, VA
    543.1 miles
    10.725 gallons
    $2.259/gallon
    $24.23 total
    50.64 calculated mpg
    53.4 computer mpg on tank.
    $0.0446/mile
    33 mph avg. speed
  14. walter Lee
    1,126
    376
    Maryland
    549.3 miles
    9.180 gallons
    $2.499/gallon
    $22.95 total
    59.84 calculated mpg
    61.3 computer mpg on tank.
    $0.0417/mile
    23 mph avg.
    OE Yokohama Avid S33d, tire pressure 44/40 psi
    ScangaugeII
    no grill blocking
    #334 walter Lee, Apr 26, 2015
  15. CardiffChris
    CardiffChris Member
    94
    63
    Cardiff by the Sea, California, USA
    2014 Prius Plug-in
    57.7 Last Tank
  16. HaroldW
    HaroldW Active Member
    716
    95
    Grand Forks BC Canada
    Wesayso. How are the ep -20 tires treating you? Did you purchase two more or are you still only running two. Hal
  17. wesayso
    wesayso Member
    385
    35
    Hampton, VA
    Not sure what you mean with the 2 tire comment. I replaced the original ep-20 tires a few months back at 41K. They were shot. Replaced with Michelin Energy Saver A/S.
  18. wesayso
    wesayso Member
    385
    35
    Hampton, VA
    478.8 miles
    10.123 gallons
    $2.359/gallon
    $23.88 total
    47.3 calculated mpg *
    49.9 computer mpg on tank.
    $0.0498/mile
    48 mph avg. speed
    *Over 400 miles at 70-80 mph.
  19. wesayso
    wesayso Member
    385
    35
    Hampton, VA
    498.1 miles
    10.578 gallons
    $2.359/gallon
    $24.99 total
    47.08 calculated mpg *
    49.3 computer mpg on tank.
    $0.0501/mile
    48 mph avg. speed
  20. John75
    John75 Junior Member
    25
    52
    Outside Philadelphia
    My first tank:
    409 miles
    9.29 gallons
    44.02 calculated mpg
    Most of my rides were higher than that, but the car did have 10 miles on it when I got it - though that couldn't have swung it much.
    Curious to see how it changes over time. My best ride (not counting 5 mile little rides) has been 28 miles @ 55.6 according to the computer.
