Tire Chains...
Discussion in 'Gen 3 Prius Accessories and Modifications' started by jack520, Feb 15, 2015.
  1. jack520
    jack520 Member
    154
    40
    2014 Prius Plug-in
    I live in the part of the country that requires tire chains sometimes.
    I would like to know what tire chains people have used on their prius and any recommendations.
    Thanks jack
  2. qdllc
    qdllc Senior Member
    1,377
    400
    Given the low profile of the Prius, I'd not bother. If you need chains, you probably shouldn't be driving the Prius in it.
    On that note, first "snow" with mine, and it did okay getting home, but couldn't make it up the drive (not surprised). The car generally stunk when it came to keeping the windshield clear. Even on full defrost the wipers and heat wasn't keeping the ice off the glass (like my pickup truck could).
  3. Accordlayingkit
    Accordlayingkit Senior Member
    1,618
    1,748
    377
    Colonial Heights, Va
  4. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,801
    Undisclosed Location
    I'd be nervous running chains on a Prius just because if they happened to break I think you could do so much damage to the wheel well and surrounding area.
    However, I realize some people live and drive in environments where having chains available and using them is not really a matter of choice. And the OP does say "Requires Chains".
    My question is it "Requires Chains"? or Requires Traction devices? Because I'm curious about Tire Socks, Sno-Claws, and some of the alternative traction devices available. I've done some looking online and some of the alternatives look interesting. I'd be curious if anyone has tried any of those alternative to chains.
    If you are sold or forced to run chains, I don't think it being a Prius would really change the formula much. You want good quality ones, that fit the tires you are running, and you want to install them properly. Then be very, very careful.
    I'm probably NOT a good person to attempt to answer this question, as even though I think I need to run snow tires, the winter environment I'm mostly driving in is NOT so extreme that I need chains. And I do think if it got to that level where I live, I'd simply be NOT driving the Prius.
  5. Mendel Leisk
    41,771
    I'd second the above, ARE chains mandatory in some places/conditions? Or is it chains OR winter tires? Don't know, and curious.
    My guess would be chains are only necessity if you're driving across a spectrum of weather condition, don't want to end up driving snow tires through a desert, for example.
    #5 Mendel Leisk, Feb 18, 2015
  6. qdllc
    qdllc Senior Member
    1,377
    400
    Things may have changed, but in the years when I was shopping for chains, I went with chains that had "ice bars" (Vs that bite into ice). For FWD cars, the only recommended "chains" were more like the cable used to make locking cable for bicycles. It would work LIKE a chain, but it was intended to work with the low-profile of most FWD cars. Nowhere near as effective as regular chains.
    Doesn't snow bad enough around here to have snow tires on a vehicle.
  7. css28
    css28 Senior Member
    1,566
    443
    Suburban Detroit
    Please add your location to your profile.
    Give us a clue about where "around here" is.
  8. GregP507
    GregP507 Senior Member
    3,002
    481
    Nope. I wouldn't recommend them for a Prius. If you can't get there with good winter tires, don't try.
  9. jack520
    jack520 Member
    154
    40
    2014 Prius Plug-in
    I live around Tahoe, there are often snow chain requirements or 4 wheel drive requirements.
    I have a 4Runner with real snow tires, but sometimes I need to drive my prius too.
    You guys confirmed my opinion...do not drive it when chains are required.
    Jack
  10. qdllc
    qdllc Senior Member
    1,377
    400
    Bristol, Virginia
    "Bad" snow events (effects lasting a week or more) are something that happen maybe every 5-10 years. A nice snowing might happen every 2-3 years (something that buggers things for a day or two).
  11. macman408
    1,179
    367
    Yes, California sometimes requires tire chains when there's snow on the roads. Being originally from Wisconsin, I think the conditions where they start to require chains are silly - it's probably only because there are lots of people who drive through the mountains that don't live there, and so don't know how to drive in snow.
    There are various requirements that they enforce as the snow gets worse - the first level is "snow tires or traction devices"; the second is "traction devices, or 4WD with snow tires"; the third is "traction devices, no exceptions". The definition of "snow tires" is pretty weak; 6/32 tread, and an M+S label on the sidewall - which even the OEM all-weather tires have. I don't live close enough to the Sierras to regularly have to drive in chain controlled areas, but I've heard that by the time conditions get bad enough to require traction devices on all vehicles, they often just close the road altogether.
    And as I've implied, the law says traction devices, which includes chains, cable chains, and alternative devices - they list Spikes Spider as an example. I remember seeing tire socks a long time ago, and they were not approved then - more recently, it seems like they're probably approved, but still at the discretion of the person manning the chain checkpoint (if there is one), who might determine that only chains are sufficient and make you turn around.
    I got a set of Thule K-Summit (which would probably fall under the "traction devices" category, since they're not plain chains) cheap from Amazon about 3 years ago - but given that the drought here has meant not much snow, I haven't had to drive through the mountains during a chain control since then. Still hoping for a big snow so we can keep drinking water next year, though...
    Personally, I see no issue using low-profile cables or something similar on a Prius (though several friends of mine have torn cable chains to shreds after only a couple uses - maybe they'd last longer if they washed the salt off and thoroughly dried them afterwards, though). Heed the 30 mph speed limit, use care when driving, and it shouldn't be a problem.
  12. jack520
    jack520 Member
    154
    40
    2014 Prius Plug-in
    MacMan
    Thanks...
    My Family is from Portage Wi so I grew up knowing how to drive in snow...
    I am thinking about buying the Thule K-Summit too...they are expensive and not sure how often I will use them.
    I live both near Sacramento and Tahoe area, so I drive up there often. There has been no snow so we are in deep trouble...
    Once again thanks for the input..
    Jack
  13. jack520
    jack520 Member
    154
    40
    2014 Prius Plug-in
    Snow tires are not sufficient. The roads are either clear or require snow tires with some traction type device. If you have a 4 wheel drive with snow tires then you can go too. There is another condition which is 4 wheel drive with chains which I have never seen. I do have chains for my 4Runner with real snow tires and sometimes need to chain up all 4 wheels to get through some of the local roads.
    We usually get a lot of snow, about 10-15 feet a year....
    hope this answers your question..
  14. fuzzy1
    10,560
    Alberta is different than California. Law enforcement and highway departments have policies tuned to their particular latitudes and driver clientele. So conditions that might draw no notice in northern Alberta, may produce an officer with a gun standing in the middle of the road enforcing chain requirements on I80 in California.
    #14 fuzzy1, Feb 21, 2015
  15. css28
    css28 Senior Member
    1,566
    443
    Suburban Detroit
    "...an officer with a gun..."
    "Put on your tire chains or I'll shoot!" :)
  16. fuzzy1
    10,560
    You do have another option: turn around and go back. That is what nearly everyone was doing at Donner Pass when the enforcer waved my old Subaru through the checkpoint. The DOT worker there didn't appear armed, but I've seen armed State Patrol and National Park officers doing the same job here in Washington.
    I used to be somewhat facetious with that 'officer with a gun' bit. That was before the killing of NPS Ranger Margaret Anderson on Mount Rainier, by a suspect in a multiple shooting earlier than morning. The perp (an ex-soldier from nearby Joint Base Lewis-McChord, likely with untreated PTSD) blew through a chain checkpoint low on the mountain, then found himself trapped between two patrol vehicles higher up.
    Many of my friends knew Margaret through our volunteer work in the Park. I didn't know her, but do know the officer who was staffing the checkpoint in question, and who chased and was also fired upon by the killer.
  17. GregP507
    3,002
    481
    Nothing in real life could be as silly as that sounds.
  18. fuzzy1
    10,560
    I take it you haven't witnessed this multiple times in multiple places.
    I have, though not on your side of the border.
    #18 fuzzy1, Feb 23, 2015
  19. sdtundra
    sdtundra Senior Member
    1,314
    193
    Sacramento, CA
    This is straight from the Caltrans site..the picture is from the Donner Pass rest stop December 11, 2014.
    If I have 4-wheel-drive, do I need to carry chains?
    Yes. Even though weather conditions may not warrant the use of chains on 4-wheel-drive vehicles at a particular time, to enter a chain control area, you must have a set of chains (for one drive axle) for your vehicle in your possession. If conditions worsen or you have trouble controlling your vehicle, you must stop and install the chains.
    If I have snow tires, do I need to carry chains?
    Yes. Even though weather conditions may not warrant the use of chains on passenger vehicles equipped with snow tires at a particular time, to enter a chain control area, you must have a set of chains (one pair) for your vehicle in your possession. If conditions worsen or you have trouble controlling your vehicle, you must stop and install the chains.
    fuzzy1 likes this.
  20. fuzzy1
    10,560
    I'm suspecting that Greg and many of his northern cohorts would not feel that chains are necessary in the particular conditions shown in that picture. And for most drivers in his region, that may well be true.
    But down south here (including the coastal ranges of WA and OR too, not just CA), those conditions will catch many drivers flat-footed and bald-tired, more than enough of them to plug up and close the road for many hours while the police and DOT and tow trucks sort out the wreckage. Lather, rinse, and repeat several times per day. Hence the requirement to have chains, sometimes installed, sometimes just in possession when conditions may change rapidly. And sometimes enforced at checkpoints, by a law enforcement officer standing in or alongside the road, who of course has a gun on his/her hip.
