Headlight low beams failed during dinner
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by CuriousMark, Feb 19, 2015.
  1. CuriousMark
    CuriousMark Junior Member
    Palmdale, CA
    This is a new one for me. My wife and I pulled into a parking space at a restaurant after dark. The headlights were working fine and illuminating the car in front of me. I powered off and then, based on the wifely stare, shut the headlights off. We went in and ate. After dinner I came back to the car, started it and turned the headlights on and got nothing. No flash, just nothing. High beams were fine. Cycling the light switch made no difference. It is as if the low beam relay (I assume there is one) failed when the lights were turned off before getting out of the car.
    The bulbs are halogen replacements that are about 4 months old, I replaced them both after one failed last fall. The original bulbs were OE and had lasted six years. We don't typically leave the lights on all the time. My wife, who is the primary driver, is finicky about such things.
    Is there anything else I should look at other than trying to check fuses and locate a relay? Is it safe to assume that there is one fuse which supports both low and high beam? If not, then I could see a fuse take out both low beams.
    Thanks for advice and suggestions.
    CuriousMark
  2. valde3
    valde3 Senior Member
    2,002
    749
    Finland
    Check that they both didn’t just fail at the same time. You can check this by measuring voltage from connector that connects to bulb. Or connecting new bub to the connector without installing it into it place. Or just replacing one of the bulbs.
    CuriousMark likes this.
  3. CuriousMark
    Palmdale, CA
    I can do that. I checked and found there are four fuses, so the likely hood of two failing at the same time, or two bulbs failing at the same time is a possibility to check as you suggest. I found another thread here after posting which also suggests tapping the headlight dimming relay with the handle of a screwdriver, so I will try that too.
  4. Former Member 68813
    3,524
    983
    US
    let me get it right, you went out to dinner and headlights went out to lunch?
    CuriousMark and ftl like this.
  5. Britprius
    Britprius Senior Member
    5,194
    1,921
    Herefordshire England
    Below is the circuit diagram the relay marked "DM" near the top of the page is your most likely problem. This circuit is for cars with DRL's but it makes little difference.
    John (Britprius)
    frodoz737, CuriousMark and ftl like this.
  6. CuriousMark
    Palmdale, CA
    Nice diagram, thank you very much. I will attend to this all when my wife gets home from work.
  7. Longinus876
    Longinus876 Member
    105
    Long Island
    My driver's side halogen low beam always goes out. Filament is good. Wire seems good. No idea about any relays or fuses. Any help appreciated.
  8. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,802
    2017 Prius c
    So.....what do you do to FIX it ?
    Or does it come back on by itself ??
    P.S. This is a 3 year old thread.
