Build of Chinese Double DIN (2DIN) radio/nav/carkit (incl photo's)
Discussion in 'Gen 2 Prius Audio and Electronics' started by Gerard Altena, Feb 23, 2015.
  1. Gerard Altena
    Gerard Altena Junior Member
    In this thread I will make a diary about all my effords to build a chinese 2din radio/nav into my Prius 2.
    It's a Prius 2 without nav, without JBL.
    I will try to post as many pictures as possible.
    Every step will be documented.
    Starting point:
    Prius 2, no nav, no JBL
    Carkit build between the radio and the speakers (parrot) , so I have ISO-connections
    Goal:
    2DIN chinese nav/bluetooth/aux/usb etc
    low install costs
    23-2-2015.
    Made my firsts efforts.
    Bought a second hand 2DIN chinese nav/radio (100 euro).
    Incl. ISO-connections. But the B-connector is missing (for steeringwheel-control, rearview-camera, etc.. But fully functional
    If anyone recognizes the B connector, please help.
    23-2-2015.
    Dismanteled the dash, to find out if I could.
    Used the PDF from META to get the idea.
    Found a video online for the last details.
    No problems
    23-2-2015
    While taking the dash off, I tried disconnecting the 10-poled wire which causes all the AC problems.
    Disconnected like this it made te AC go bad.
    After adding the 68 Ohm resistor (just plugged it in the other end of the connector) and the problem was solved.
    I figured out that the connector is supposed to hang lose, after installing an aftermarket radio. Anyone ever tried to solve the problem like this, and not soldering it between the cables 9 and 10?
    Of course I will do it without the possibility to short circuit.
    Still no idea how to embed google+ photo's in this forum
    update 24-2: solved. Google chrome didn't work. Used firefox instead
  2. Britprius
    Britprius Senior Member
    5,194
    1,922
    Herefordshire England
    At the bottom of the box where you compile your text is a button marked "upload a file" click on that button to bring up a box with "choose a file" click on that then choose the file (picture (s) ) you wish to post then choose open, and wait for the pictures to load. Once loaded you can choose "thumbnails or full".
    Hope this helps.
    John (Britprius)
  3. Gerard Altena
    I can click on "upload a file"
    I can choose the file
    It will upload untill 100%, and then there's a message:
    The following error occured
    There was a problem uploading your file.
    They are normal jpg's
  4. Britprius
    5,194
    1,922
    How large are the files. Max 5 MB
    John (Britprius)
  5. Gerard Altena
    Found the problem:
    It doesn't work with my computer and google chrome.
    No problem with my iPad or my computer with firefox.
    Old posts updated with photo's
    @Britprius: thanks for the help
    #5 Gerard Altena, Feb 24, 2015
  6. Britprius
    5,194
    1,922
    I do not think that Chrome is the problem as that is what I use "famous last words":(
    John (Britprius)
  7. Gerard Altena
    Dismantled my dash again today.
    It is really easy. Took me 15 minutes (including photo's)
    Made some pics.
    use the pdf in post #3 as a guideline.
    Always pull at the place of the yellow pins you see in the photo's !!
    1. remove left vent.
    pull upwarts at the bottom. There are three yellow clamps that must be loosened. You will need some force to do that.
    After that gently loosen up the top.
    2. unscrew two screws. One behind the vent you just took away. One somewhere under the steering wheel near your knees.
    3. Pull the part you just unscrewed toward you. Use the 4 corners.
    4. Remove the part that's on top of your steering wheel. Use the corners. (photo taken through the windshield)
    5. Remove the pin that is located near the 12V connector.
    After that remove the plastic part. (two upper corners)
    6. Remove the airvents left and right from the center console. Same principle as the first one.
    7. Loosen up 2 screws that are just beside the center compartment with tilting door.
    Than pull the whole part towards you.
    8. Remove two bolts that are located left and right from the display.
    Than pull at the left- and right-bottom of the display towards you (where the red plugs are)
    9. 4 screws remaining. At the top the left and the right one. Leave the one in the middle.
    Under the radio there are two more screws.
    Next phase: the wiring.
    Got a Toyota to ISO and back - kit from my toyota dealer. He installed my carkit for me.
    There are three wires bypassing the ISO-connectors, but they weren't attached to anything in the wiring loom as I found it.
    The mighty 68 OHM- trick
    In order to have a proper AC, you need to connect pin 9 and 10 of the 10-pole connector with a 68 ohm resistor.
    I took a resistor, heatshrunk it (leaving about 1 cm free at both ends).
    Plugged it in the other end of the connector.
    Bend it over.
    And put some PVC tape over it.
    Did it this way, so I didn't have to solder, and didn't have to make a permanent adjustment to the car.
    IMG_1036.JPG IMG_1037.JPG IMG_1038.JPG IMG_1039.JPG IMG_1045.JPG IMG_1046.JPG IMG_1053.JPG
    Works like a charm
    Hardest part: Fitting the new radio in the excisting frame, at the right heigth and the right angle.
    First: measure up the distances of the stock radio. Don't forget to measure also the vertical measurement (I did)
    Try to fit the new radio in the frame. Try to fit it in the dash of the car, mounting only the radio, the glove compartment under the radio and the prius screen.
    Got it wrong a couple of times. So the radio was to far down. Sliding door compartment would not fit.
    After 5 takes, I got the right holes in the frame lined up with the right holes in the radio.
    Got it right at last.
    Will take pictures, but it was becoming dark, and the connector of the GPS turned out to be faulty (fixed it already).
    Will put everyting back in the PRIUS tomorrow.
    #7 Gerard Altena, Feb 24, 2015
    MiRoXFin likes this.
  8. Gerard Altena
    Bolted everything back together.
    Works fine. Still some holes to fill (don't have a doubleDIN kit)
    25-2-2015
    Aaron Vitolins likes this.
  9. Prius408
    Prius408 Junior Member
    34
    San Jose, CA
    If you buy a double din kit it still won't fit unless you customize it. I used a dremel tool to cut up the kit to make it work
  10. Gerard Altena
    Thanks. I'll try to fabricate something out of roofmate. And paint it black
    Henk likes this.
  11. 69shovlhed
    69shovlhed Surly tree hugger
    2,170
    752
    Delaware
    there is a kit or was, I don't know if its still made which is just 2 pieces of black plastic which uses the Toyota plastic clips to fill the holes on each side of the head. no dremel needed. an exacto knife perhaps if your picky about the fit, but looks pretty good imho.
  12. Gerard Altena
    Did some handcrafting.
    Took a piece of roofmate (dense blue foam) and cut a piece thats the right width and lenght.
    Put it in the gap next to the radio.
    Took a pencil and lined out where the edge of the radio was.
    Cut roughly with an exacto-knive.
    Used a electric sander to smooth things out.
    Than sprayed two coates of paint (mat-black)
    Di
  13. Melchior
    Melchior Junior Member
    74
    Netherlands
    Thank you for sharing this project. I would like to do something similar to mine but do not want to lose the steering wheel audio controls. Were you able to keep them working with this setup?
  14. 69shovlhed
    2,170
    752
    Delaware
    metra axxess unit allows the steering wheel buttons to work if your head unit doesn't have that capability built in.
  15. blackavenger
    blackavenger Junior Member
    35
    Bland Strand
    Four Touring
    So who is the manufacturer of the installation kit? This looks REALLY clean!! I hope I'm still able to track it down.
  16. Mgrad92
    Mgrad92 Junior Member
    Tampa Bay, Fla.
    I don't have any personal experience, but I've seen Crutchfield sell something that sounds like what you're describing:
    Vehicle-specific Mounting Kits at Crutchfield.com
  17. 69shovlhed
    2,170
    752
    Delaware
    I think the kit was made by scosche.
  18. blackavenger
    35
    Bland Strand
    Four Touring
    Thanks, shovlhead!! On the hunt.
