hsi screen not coming on
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by ramattos, Feb 24, 2015.
  1. ramattos
    ramattos Junior Member
    57
    Bethlehem PA
    just this morning drove to work normally but after sitting in the car for less than an hour with the radio on in acc mode the 12v battery was dying. hooked up my booster pack and then started the car. when it came on noticed the hsi screen was blank. hit ev mode and got the beep to tell me unavailable. i believe i remember getting a letter about that screen not coming on but cant remember if it was my 08 or the 10 model. dealership says there is no recall.
    ive pictures of the screens that i took at the time
    as you can see everything else is on but that screen. have an appt with dealer in 2 days and hope to have something to tell them
  2. Blizzard_Persona
    1,787
    944
    Pa.
    2023 Prius Prime
    XSE
    Year, Model of your car?
    My 2015 display does not look like the pic you posted…..
    and an hr of listening to tunes should not kill the battery...
  3. ramattos
    57
    Bethlehem PA
    its in the side bar. 2010 prius model 3 i think. and i am aware that an hour shouldnt kill it as ive already done it for 3 hours before starting it
  4. PriusGuy32
    1,417
    510
    Harrison Township, Michigan
    Oh, you've done it now!!!!
    Hehe jk. Im going to state the obvi, but have you pressed the DISP button? If that doesnt work, I'd start checking fuses.
  5. ramattos
    57
    Bethlehem PA
    yes pressed the disp button still nothing, and i highly doubt that a fuse would blow with nothing extra on. the only thing i can think of is that the cold(1 degree outside) effected it somehow.
    i did look up the notice and it was for the 2nd gen.
  6. PriusGuy32
    1,417
    510
    You never know.... Especially after using a boost/jump device. It pays to check, at least for process of elimination. I am unaware of any cold weather combination meter issues with the Gen3.
  7. Easy Rider 2
    Easy Rider 2 Senior Member
    1,584
    257
    Ocala, FL
    I don't think that part is very unusual. Some other minor stuff likely is drawing power too.
    If the battery wasn't "weak" before that, it probably is now......especially if you have had to "jump start" it before.
  8. ramattos
    57
    Bethlehem PA
    ok, its working again. my guess is that the extreme temp coupled with low 12v battery caused that particular screen to not turn on. the exact solution is unknown because i have a heater (120vac) and a booster pack in the car and the outside temp has risen slightly. glad to see that it corrected itself though because now i can see my pathetic mpg again.
    PriusGuy32 likes this.
  9. PriusGuy32
    1,417
    510
    Sorry to hear that you are disappointed with your mpg's - thats a whole different topic. Mine suffer in the wintertime too, I do my best to counteract the situation.
    Glad to hear that the problem resolved itself. I park my Prius outside and it was -18f, and -8f the day before that and I didnt have any issues. Maybe your Prius is ashamed of its lower mpg's and didnt want you to see :D
  10. Easy Rider 2
    1,584
    257
    Ocala, FL
    Does that mean that you are not going to have anything checked out ??
    I think your 12 V battery needs a thorough charging and a test.......at a minimum.
  11. PriusGuy32
    1,417
    510
    I have a feeling he'll be back ;) Cant reach 'em all the time, EastRider.... lol
  12. ramattos
    57
    Bethlehem PA
    i stillhave the appt for the inspection and i will have them do a charge and test of the battery at that time too. and that could be a reason to my lower mpg as i know they have a big impact.
    and i wouldnt doubt that its ashamed of itself, it seems to have telepathy and knows what happened to its predecessor...
  13. Morfeas
    Morfeas Junior Member
    greece
    Same thing here MFD died after the 12V battery died.
    Actually after jump starting the car the middle screen and the Head Up Display died.
    The car though was functioning normally ...
    Came to dealer, he said this is normal for a dead 12V battery. The battery replaced and everything came back to normal ... Took the car happy drive back home when I noticed that the arrows showing the energy distribution on the MFD have vanished...
    After the dealer things that my OBD reader has ruined the plug off the car and they cannot connect their reader blah blah blah I brought the car back today again and as they told me they performed some kind of reset and everything works fine by now...
  14. PriusGuy32
    1,417
    510
    Interesting!!
    Now Im curious about where the OBD plug receives its power from.... Usually its a fused circuit, that is shared with other peripherals.
  15. kc410
    kc410 Active Member
    262
    250
    2010 Prius IV
    Fuse appears to be 7.5A & is labeled OBD per the attached wiring diagram.
  16. Goatmother
    Goatmother Junior Member
    Chemung, NY
    Reading the thread, you guys are great! Glad I joined. Still haven't made up my mind on the 2011. . . .
