2013 Persona Project..
Discussion in 'Gen 3 Prius Accessories and Modifications' started by Xterra72, Oct 29, 2014.
  1. Xterra72
    Xterra72 Senior Member
    1,434
    1,681
    Another nice day in Cali.:cool:
    sonnyd510, BPZVW30 and Burna J like this.
  2. Sfcyclist
    Sfcyclist Senior Member
    1,621
    376
    SF, CA
    go for the 500!
    Xterra72 likes this.
  3. BPZVW30
    BPZVW30 Member
    73
    141
    Shiny Blizzard Pearl @Xterra72!
    Nice grill inserts too.
  4. Xterra72
    1,434
    1,681
    @BPZVW30, Your headlights and drls are looking clean. Nice job on the transformation. (y)
    #124 Xterra72, Feb 27, 2015
  5. Blizzard_Persona
    1,787
    948
    Pa.
    2023 Prius Prime
    XSE
    Xterra72,
    I wish it would get warmer around here darnit.
    My last 3-4 tanks have been in the 39's mpg wise and I have not broken 400 miles a tank since my first tank, and I drive like a grandma as I said before (55 mph almost all the time, have my tires 44/42, try to barely use the heater if at all, have the lower grill blocked, don't do a lot of short trips).
    I just filled up in Delaware as it was $2.35, as opposed to $2.49+ back home and I got 39.49 mpg calculated!! Kinda blows as imagine I was not doing all the above i'd prob be at 35'ish mpg :(
    Warmer weather should def improve my stats though.
    Meanwhile you are killing it on the west coast :)
    #125 Blizzard_Persona, Feb 27, 2015
  6. Xterra72
    1,434
    1,681
    At least your gas is not at $3.22 per gallon. Our gas prices has gone up quite a bit since my last fillup.
  7. Blizzard_Persona
    1,787
    948
    Pa.
    2023 Prius Prime
    XSE
    True.
    Then again that's the price you pay for living in Palm tree land. ;)
    I moved out of there in 2004...
    Coming bak to visit for a couple weeks in June though...
  8. Xterra72
    1,434
    1,681
    Suppose to rain but shined her up anyways.:D
    #128 Xterra72, Feb 27, 2015
    Burna J and BPZVW30 like this.
  9. BPZVW30
    BPZVW30 Member
    73
    141
  10. Xterra72
    1,434
    1,681
    Just called the place that installed it and they called it Oracal film dark gray. I think it's more of a light smoke.
  11. BPZVW30
    BPZVW30 Member
    73
    141
    Got it. I'll check around for that.
    thanks.
  12. Xterra72
    1,434
    1,681
    Results of my last tank and my third fillup since my quest for high mpg.(y)
    20150305_195631.jpg 20150305_195725.jpg 20150305_195733.jpg 20150305_195745.jpg 20150305_200030.jpg
  13. Xterra72
    1,434
    1,681
    Another empty tank
    Another Another fillup
    (y) I can't complain. The weather has been steady At 65 -70 degrees.
  14. g33kguy
    g33kguy Junior Member
    Virginia
    Could you give info on the upgraded sockets in the lower center console? Thanks!
  15. Xterra72
    1,434
    1,681
    This is an exact plug n play to replace the oem. You can purchase from global rakuten or ebay by searching toyota prius zvw30. You will surely get a hit on this. Good luck.
    theguppies likes this.
  16. Sfcyclist
    1,621
    376
    SF, CA
    The low gas prices was nice while it lasted.. I pushed it to to just over 500, 2nd time. You are right there.. clearly based on your mpg you can do it.. Our 17" wheels are not that bad.. but maybe the Toyo's are that good?
    [​IMG]2nd 500 mile tank
  17. Xterra72
    1,434
    1,681
    I have done it once or twice before the software update and when i still had all four oem tires But never took a picture of it.
    What I don't get is how people can get the 600 maybe even the 700 mile tank. Maybe possible with 15s but I don't see getting it with 17s like that person from Florida.
  18. Sfcyclist
    1,621
    376
    SF, CA
    Seriously.. Prius tank size is 11.9 so say you push it to 11.5 for simple math sake.. 600/11.5 = 52mpg. 700/11.5 = 60,87 mpg! 600 I can see that but 700.. I bet they are literally not stopping and just keep on rolling. Nevertheless, quite a feat. Impossible where we live.
  19. Xterra72
    1,434
    1,681
    Think you're spot on.
  20. Xterra72
    1,434
    1,681
    Got an oil change. Here are better pictures
    20150403_154736.jpg 20150403_154812.jpg 20150403_154838.jpg 20150403_155029.jpg 20150403_155043.jpg
    Mechanic even used it as a hanger.(y)
    Dylan Doxey likes this.
