Trouble with install of Clazzio seat covers
Discussion in 'Gen 2 Prius Accessories & Modifications' started by Freedom, Feb 23, 2015.
  1. PriusGuy32
    1,417
    514
    Harrison Township, Michigan
    Just to keep you on the edge, Im not telling :p
  2. Freedom
    Freedom Active Member
    539
    73
    Northeastern MA
    Thanks for this! I am going to wait for the weather to be warmer; currently 9 F here.
    Thing with the rear seat bottom is, there is just me. From everything I have read, for that piece only, I am definitely going to need a second person. It's not the releasing of it, I can follow online pics and instructions. It is the hauling it out of the car onto the driveway. And then shoving it back IN the car. Petite female here, don't think I need to risk a back issue needlessly. So I'm thinking that for that one piece I will definitely enlist help. The rest of the car, I can work my way through. Just need some warm weather.
    At this rate, it could be Fourth of July before I can put them on! With this cold, and 5 feet plus of snow on the ground, it is hard to even imagine we will ever warm up again.
    This was one 'down side' of ordering them in Sept which I had not anticipated. And the past 4 winters, this would not have been an issue!
  3. Daves09prius
    Daves09prius Active Member
    680
    161
    Gettysburg, PA
    Please keep the priuschat community updated on your install. I'm actually going to do this mod too! Hope your install gets easier once the temps warm up.
  4. littlehandegan
    littlehandegan Junior Member
    Charleston, SC
    I will be installing my Clazzio's this weekend. Will take some pictures and let you know how hard it is!
  5. Justdidit
    Justdidit LVNPZEV
    1,880
    711
    75
    Carrollton, Texas
    Four Touring
    I'm tempted to do this as well AND do the heating element. Def let us know - these Canadian temps are a huge change from Sunny SanDiego.
  6. Justdidit
    Justdidit LVNPZEV
    1,880
    711
    75
    Carrollton, Texas
    Four Touring
    I'd offer to help but I'm no where near close - I've had the rear seat in and out several times. I don't recall and special tricks to share to help you out tho. :(
  7. PriusGuy32
    1,417
    514
    Good Luck!! You will love the finished product, and be proud that you tackled this yourself (y)(y)
  8. littlehandegan
    Charleston, SC
    Friend and I did it, took about 1 hour.
    Look pretty good! Take your time and you will be happy.
