MFD battery indicator
Discussion in 'Gen 2 Prius Main Forum' started by ml86, Apr 11, 2006.
  1. ml86
    ml86 New Member
    92
    Tulsa, Oklahoma
    What does the change in color mean for the battery charger indicator (bars) on the MFD screen?
  2. efusco
    efusco Moderator Emeritus
    19,891
    1,196
    Nixa, MO
    <div class='quotetop'>QUOTE(Max Smart @ Apr 11 2006, 02:23 AM) [snapback]237950[/snapback]</div>
    As you can see, the bars turn pink at the last two bars, are blue anywhere for 3-6 bars and all turn green when up to 7th & 8th bars. See below for the actual SOC (state of charge) at each of those levels. The colors are just supposed to make you aware...green = good--lots of energy to use. Pink (kinda like red) low SOC, less power available.
  3. daniel
    14,487
    1,519
    Spokane, WA
    <div class='quotetop'>QUOTE(efusco @ Apr 10 2006, 11:47 PM) [snapback]237953[/snapback]</div>
    Evan: The lower image in your post does not seem to work.
  4. Rancid13
    Rancid13 Cool Chick with a Black Prius
    2,452
    Los Alamitos, Orange County, CA
    <div class='quotetop'>QUOTE(daniel @ Apr 11 2006, 09:24 AM) [snapback]238037[/snapback]</div>
    It doesn't appear in the thumbnail, but when I clicked on the image, it enlarged the image and I could see it fine.
    In the 2006, the 'pink' bars are actually more of a darker purple than pink. Not that it matters... I finally saw them for the first time last week during an ~10-mile 6% grade uphill climb. :)
  5. daniel
    14,487
    1,519
    Spokane, WA
    He fixed it. It works fine for me now. Thanks, Evan.
  6. efusco
    19,891
    1,196
    Nixa, MO
    <div class='quotetop'>QUOTE(daniel @ Apr 11 2006, 07:29 PM) [snapback]238296[/snapback]</div>
    I didn't do anything, maybe the linked site was down or something.
  7. ml86
    ml86 New Member
    92
    Tulsa, Oklahoma
    Very helpful. Thanks.
