299,999+ Mile Club
Discussion in 'Gen 2 Prius Main Forum' started by usbseawolf2000, Apr 16, 2010.
  1. 200Volts
    200Volts Member
    439
    46
    Northern CA
    Longbow,
    I would not spend $2k on a new catalytic converter/pipe. You will likely foul it again in about 30-40k miles (this happened to me). If you search on Craigslist for "Prius Parting" you will likely find someone, or a salvage yard, that will sell you the "exhaust pipe, middle section" (that just so happens to include the cat). I paid $500 for a used one. Took a garage 30 minutes to replace for $70 (or do it yourself with 2 jack stands). If you are stuck, in an emergency, then get a 0.25" dia drill bit, about 12" long, and drill a dozen holes in the first layer of the cat to get you home (it will run like new, caution light will be on until you replace it - right away).
    telmo744 likes this.
  2. longbow
    longbow Recovering SUV Owner
    62
    34
    Bayfield County, Wisconsin
    200Volts I appreciate your perspective. I have considered this as a choice. However I have had excellent results from my dealer's work and I drive too much to mess with used parts. It goes in Tuesday and well be ready for another couple hundred thousand miles.
  3. SC Prius
    SC Prius Junior Member
    Sumter SC
    I have a 2006 with 298,725 miles on it. I have not changed either the HV battery or the 12 volt battery. I am going to replace the 12 volt this weekend though, and would appreciate suggestions on replacements. The transaxle is original fluid, I have changed plugs twice, did recall work and I'm on my third set of tires currently using Falken Sensia. They are a bit loud but am still getting 46 mpg, I drive 144 miles a day for work. I have not changed my brake pads yet either. I did recently get a P0420 code and that is the reason I'm looking to change my 12 volt battery.
  4. Yakoma
    Yakoma Active Member
    470
    125
    sss
    Man, looks like you've got a warhorse there. Congrats! (y) No 12V in 8+ years....wow.
    Personally, I'd look for good pricing on a Toyota OEM battery ($150-175). Maybe the service manager at one of the dealerships will cut you a discount if you ask and show them the 300K Prius. If not, I'd still be tempted to pay the 20% difference over the Optima to get the OEM.
    If it were mine, I'd change the tranny fluid. But you have 300K on yours and I only have 85K on mine so I defer to seniority.
    Don't know about the code, but I'm sure someone will chime in on that.
  5. longbow
    62
    34
    323015 and still the original 12 V here. 7 Northern Wisconsin winters!
    telmo744 and SC Prius like this.
  6. Melchior
    Melchior Junior Member
    74
    Netherlands
    and then...
    Just incredible. Whoever heard of brake pads lasting 300,000 miles on a 'normal' car?! or even 30,000! Love it.
  7. SC Prius
    Sumter SC
    I was going to have it changed about 100,000 miles ago, but the dealer did not want to do it. He said it was sealed for life and if it wasn't giving me trouble leave it alone. Other posts I've read here are adamant about having it changed. I won't now that it has so many miles on it, but will on the 2012 V that we got last year.
    My odometer is now at 307,964, I had the display changed a couple of years ago under the recall.
    #867 SC Prius, Mar 5, 2015
  8. almostrice
    almostrice Atari Rocks
    33
    Houston
    I have found my problem with the Brake, other brake, and vcs lights. Looks like the 12v battery is only reading 10.9V. I've had the car since 2009. So 6 years is pretty good. Don't know how long the previous owner had it tho.
    Great thing about the Prius, dieing 12v battery does not mean you are stranded.
  9. Yakoma
    470
    125
    sss
    ^^^ Good deal.
  10. littlehandegan
    littlehandegan Junior Member
    Charleston, SC
    Melchior, telmo744 and Aaron Vitolins like this.
  11. kammssss
    kammssss Member
    287
    86
    SoCal
    I made it last week. Best car ever. New 12v battery. Same HV battery. Same brakes. 3rd water pump. Mobil 1 synthetic oil. Btw, the odometer cluster is stuck at 299,999k even after a new replacement last spring. Hope to go another 200k. 20150324_132621.jpg
    Aaron Vitolins and Yakoma like this.
  12. hill
    8,836
    That is simply killer !! Congratulations!
  13. apt5020
    apt5020 Senior Member
    881
    1,294
    Prius City, CA
    You on the original transmission? No slipping, etc.?
  14. Paul Schenck
    Paul Schenck Active Member
    523
    306
    Fresno, California
    Start planning where you want to get that traction battery. I know I thought mine was an immortal like Thor. I was able to get Gen 3 cells in a Gen II BUILD BUT PAID. $3000. Hope with planning you do better.
    iPhone ?
  15. Paul Schenck
    523
    306
    Fresno, California
    Use your trip meter carve a notch in your steering wheel every 10k and watch your savings grow.
    iPhone ?
    SageBrush likes this.
  16. telmo744
    telmo744 HSD fanatic
    2,181
    769
    Portugal
    HSD transmission does not have any friction-intended parts, except for the torque limiter system, which never heard of problems before.
  17. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,001
    Fort Lee, NJ
    Champion Toyota dealer sells brand new Gen2 pack for about $2,000.
  18. hill
    8,836
    Maybe that $3k was w/ labor?
    Paul Schenck likes this.
  19. kammssss
    kammssss Member
    287
    86
    SoCal
    I have the same transmission; it seems to be running fine, never sense a slip. Going to replace the struts/shocks this week. Lifetime mpg average is 45. Oil is burning @1qt for the first 5k. I'll report about the next 5k later. I change my oil every 10k.
  20. kammssss
    kammssss Member
    287
    86
    SoCal
    Do you know if the cells were produce recently, or like 2009 (which were the last batch of 2nd gen.)?
