Removing upper passenger seat back rest
Discussion in 'Prius c Accessories and Modifications' started by Jim at Growing-Faith.org, Mar 7, 2015.
  1. Jim at Growing-Faith.org
    Nomad
    I am trying to remove the upper portion of my passenger seat for my 2012 Prius C. This is not the part that you sit on. It is the part where your back rests against. The part where the head rest attaches to. I'm not sure what the formal technical name of the part is.
    Anyway, I see a yellow wire running up in to it. I am worried that if I do something the passenger air bag will go off.
    Under the seat I see some wire connections.
    So basically I would like step by step help on how to remove this part. Both mechanically, and if there are any worries about air bags going off!
    In addition, I plan to keep this part of my car removed, and not have a passenger sit in this seat. Do I need to disable the air bag for the passenger side? I see it is always marked as Off on the display when it does not detect enough weight on the seat. Is there a way to permanently disable the passenger air bag?
    Thank you very much for any help.
    52,091
    seat back. why?:)
  3. Jim at Growing-Faith.org
    Nomad
    I am converting the car in to a driving tent. I have screen windows. Any help would be appreciated.
    Thank you.
  4. bisco
    52,091
    interesting, sounds cold.:p all the best!(y)
  5. sph101
    sph101 Prius 4
    156
    92
    32
    Brevard, NC
    2018 Prius
    I have cut 2 .5" plywood into 20x39" sheets and 2 4x4 into 39" lengths and 20x24" plywood with 18" legs added for head support. The 4/4 and plywoodsheets level the back out with the seats folded down and the sheets fit tin the back when the seat is up.
  6. Jim at Growing-Faith.org
    Nomad
    I am in Florida :)
    Do you have a photo of this? It is hard for me to understand. Thank you.
    #6 Jim at Growing-Faith.org, Mar 8, 2015
  7. sph101
    sph101 Prius 4
    156
    92
    32
    Brevard, NC
    2018 Prius
    Here are some picks, I use Mosquito netting instead of screens that is why I have the 12" overhang in the back
    01 C camper  stored.jpg 02 C camper  stored no carpet.jpg 03 C camper  4x4 with screw.jpg 04 C camper  assembled 1.jpg 05 C camper  assembled 2.jpg 06 C camper  assembled 3.jpg 07 C camper  assembled 4.jpg 08 C camper  assembled 5.jpg 09 C camper  assembled 6.jpg 10 C camper head support 1.jpg 11 C camper head support w screws.jpg C Camper1.jpg C Camper3.jpg C Camper5.jpg
  8. bisco
    52,091
    me too!(y)
  9. Jim at Growing-Faith.org
    Nomad
    Wow, thank you for all the photos! You really made quite a sleeping environment. I am very impressed!
    You can see my simple screens of fiberglass screen from a hardware store and some magnets.
    I live in my car, and need to store all of my belongings in there with me, so I will not be able to copy your idea, but I may try to use some of your design concepts for myself.
    Thank you very much for sharing!
