Strange Engine Cycle on a Hill
Discussion in 'Gen 2 Prius Main Forum' started by bk14, Apr 11, 2006.
  1. bk14
    bk14 New Member
    I have a three month old Prius. On my way home from work is a steep hill with a stoplight at the bottom. If I get stopped at the light, my Prius cycles the engine off an on as long as I sit there. The engine fires, stays on for five or ten seconds and then shuts off only to be started again a few seconds later. At the light, the hill is still at a decline which may have something to with it. Has anyone else experienced this and is it a problem?
    Thanks,
    -BK
  2. finman
    finman Senior Member
    1,287
    111
    Albany, OR
    2014 Nissan LEAF
    Very normal. The engine is being cycled on-off by the electric motor to use up excess charge from your downhill. Smart car, but it does do 'weird' things, all to keep that battery in a narrow range of charge, allowing an 8-year/100,000 mile warranty (longer in some stricter emissions states).
    Enjoy!
    Curt.
  3. Marlin
    Marlin New Member
    1,407
    Bucks County, PA
    <div class='quotetop'>QUOTE(BK_14 @ Apr 11 2006, 05:26 PM) [snapback]238221[/snapback]</div>
    This is apparently normal. It has been reported by many people here. Current theory is that the car is trying to drain off excess charge from the battery. I bet your Energy screen shows all green bars on the battery icon when this happens.
    The Prius tries to keep the battery state of charge (SOC) between 20% and 80% of capacity. Regenerative braking down long steep hill most likely charges the battery beyond 80% and the car repeated starts the engine to drain off the excess charge.
    That's the opinion here anyhow.
  4. bk14
    bk14 New Member
    Interesting. Thanks. That makes sense is a weird Prius kinda way.
    -BK
  5. auricchio
    auricchio Member
    921
    Cambria, CA, USA
    My guess is that spinning up the engine is the only way the car can bleed off excess power if you're not going to start moving. The car has no way of knowing how long you'll stay stopped, so it has to do something.
    I suspect they can't simply spin it without feeding it fuel, otherwise they'd do so.
    Hey...maybe the car should just turn the radio up full blast to use up some power!
  6. prius2006rocks
    prius2006rocks New Member
    159
    CA - Central Valley
    That's what I was curious about - would it take gas then I assume when the engine engages? Not use the excess electricity? Either way I don't think it affects it too much...
    <div class='quotetop'>QUOTE(Rick Auricchio @ Apr 11 2006, 03:43 PM) [snapback]238268[/snapback]</div>
  7. auricchio
    auricchio Member
    921
    Cambria, CA, USA
    Now that I think of it, the car may be spinning the engine without fuel. That would burn off the power, and the engine often can spin without fuel (as when we're over 42mph and running on electricity alone).
    When it happens again, check whether the display shows any fuel use (even though it isn't instantaneous, it'll show 99.9mpg if there's no fuel being used.)
