Check Hybrid System 2010 Prius
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by clearblue, Feb 28, 2015.
  1. clearblue
    clearblue Junior Member
    40
    us
    Started and drove off within 30 seconds "check hybrid system" popped up. Stopped.
    The car turns on and says READY along with the "check engine light, Brake, traction and yellow triangle with !" all on.
    When started the cars engine stays on constantly now. I drove down my street and looked at the charging display from battery to engine there was no movement. (first time ever saw that)
    I did a 12v test and it read 11.4-11.9 (after the engine was running in park) and retested. 14v when started.
    Any ideas? Can I drive it to the mechanic or have to tow it?
    52,063
    start with a new 12 volt, and if that doesn't fix it, move onto the hybrid battery. you're covered for at least 8/100.
    HaroldW likes this.
  3. telmo744
    telmo744 HSD fanatic
    2,181
    769
    Portugal
    Better to check at the dealer, inverters have failed before.
  4. bisco
    52,063
    i think you can drive it to the mech.
  5. PaJa
    PaJa Senior member
    678
    116
    92
    Czech republic
    The accessory 12V battery is dead. Too low voltage. surprisely the 12v battery replacement solves lot of issues. Try to borrow the one from neighborhoods or a dealership.
  6. citybug
    citybug Junior Member
    The tropics
    Hi folks ,
    What does this ' CHECK HYBRID SYSTEM' flash means? As per enclosure/pix.
    ODO reading is 119132km.
    Car is fully serviced and maintained according to schedule . Original batteries are still in used. Nothing has been changed except the tyres and the air conditioning refrigerant recharge.The car is 4.5 years old . Driven as a personal car with a daily commute of about 60-100km.
    Is the traction battery failing before the 12V battery ?
    The lead batteries shows about 12V (perhaps less, inaccuracies due to the 0- 50 Voltmeter calibration ) .The toyota folks resetted the computer system without providing the error codes. Car operates as usual now but I don' t trust the dealer . The dealers ask us to bring the car back should the flash warning reappears.
    Kindly advise.
    Thanks
  7. CARspec
    CARspec Junior Member
    53
    Eden Prairie, MN
    2014 Prius Plug-in
    "Check hybrid system" just means you have powertrain codes related to the hybrid system. These can be misfires that leads to poor performance codes and the like - it doesn't mean anything specific other than, "I've detected a malfunction and now here's some lights to bug you". You'll have to pull the code and sub code to really get a meaning, then begin diagnosis.
  8. GrumpyCabbie
    GrumpyCabbie Senior Member
    6,722
    2,121
    45
    North Yorkshire, UK
    Leave the car overnight and THEN check the 12v readings. Your car is at the ideal age for the 12v to fail (usually they last 5 years/80k miles). It's a cheap fix and there are literally hundreds of similar threads on this forum.
    So check the 12v after the car has been sat and let us all know your findings.
  9. Tapio Kuosma
    Tapio Kuosma Junior Member
    Hello. I have a 2010 Prius, but I'm not sure if my 12V battery has been replaced during it's lifespan or not. It looks clean and new (of course), but there's no date stamps etc on the battery. I measured the voltage after the Prius had been sitting for an hour or so, and the voltage was only 12,07. Seems to be quite low. I had the trunk open, so interior lights were on at the time of the measurement.
    My question is, can you point me to good instructions on how to go about when replacing the battery. There was at least one extra sensor wire or something going to battery bracket, so I guess it's not as simple as a conventional car battery replacement ? Should I replace it myself?
    #9 Tapio Kuosma, Mar 11, 2015
  10. Mendel Leisk
    41,611
    It's easy as pie. Just take a look, maybe snap a pic if you're really concerned, but really very simple. The hardest thing is getting a 10 mm wrench on the negative terminal bolt, and it's not that hard.
  11. Tapio Kuosma
    OK, thanks. Should I disconnect the small connector going to the battery bracket or just leave it in place? What's that wire for anyway? I've replaced several car batteries before, but never to a Prius and I'm just a little concerned having seen that special cable... ;)
  12. Mendel Leisk
    41,611
    I can't recall if I had to unclip that sensor. It is dead easy though.
  13. CR94
    CR94 Senior Member
    2,703
    1,177
    Northwestern S.C.
    You don't have to disconnect the wire to that sensor, but I'd disconnect it anyway to minimize chances of accidentally damaging the wire or sensor while handling the battery and bracket. Don't forget to reconnect it when finished.
    Yes, changing that battery is easy.
    Tapio Kuosma likes this.
  14. Tapio Kuosma
    OK, thanks! Can tell me what that sensor is?
  15. Mendel Leisk
    41,611
    Not sure. Temperature? Hydrogen sniffing?
  16. Tapio Kuosma
    I swapped the battery. It was very easy like you said. :) I didn't remove the mystery sensor cable, since I didn't get the connector off. :) Tried a few times, but gave up. The voltage reading with a brand new battery was 12.36 before turning on the power. Charging volt was 14.7. I charged the new battery for like an hour before installing it. Guess I have to do another measure, but I'm thinking if a have a parasitic draw of some sort?
  17. kc410
    kc410 Active Member
    263
    255
    2010 Prius IV
    That 2-wire part is a ambient temp sensor, in this case measuring the air temp of the 12V battery. The same sensor p/n (077500-5191) is located just behind the lower grill, just in front of the radiator measuring outside air temp. Its also used on a 2006 Prius where it is mounted at the center of the radiator - see Ambient Temp sensor location? Mac speller | PriusChat
  18. Tapio Kuosma
    OK, thanks! What do you think about the voltage of the new battery? It should be like 12.6 - 12.7. I should've also measured it BEFORE I connected it, so I could do a comparison... Guess I have to disconnect it once more...
  19. Mendel Leisk
    41,611
    No need to disconnect. Check with multimeter, with car shut down, doors shut, at jump connection under hood.
  20. Tapio Kuosma
    I will, thanks. That won't give me a comparison measured straight from the battery terminals with no load though...
