Rear View Mirror Package 9
Discussion in 'Gen 2 Prius Main Forum' started by billyb, Jun 15, 2004.
  1. billyb
    billyb New Member
    43
    Long Island, New York
    [font=Arial:e6cd17d6c1] [/font:e6cd17d6c1]
    Hi
    I expect to get delivery of my Silver Pacakage BC9 and was wondering if the Compass in the mirror is included. Please advise. I know the Nav. system has a compass but I would like to see the direction in the Mirror.
    Thanks, billyb
  2. efusco
    efusco Moderator Emeritus
    19,891
    1,196
    Nixa, MO
    no, there's no compass or temperture in the installed mirror.
  3. billyb
    billyb New Member
    43
    Dissappointed but thanks for your quick reply
    billyb
  4. aforkosh
    aforkosh Active Member
    412
    271
    Oakland, CA
    2023 Prius
    Note that there is a North pointer on the Nav map. By touching the pointer, you can switch between having the map oriented with North at the top or with the current direction always pointing up and the map pointer effectively working as a compass.
    On the Information and Climate screen, the measured outside temperature is displayed.
  5. ifftster
    ifftster New Member
    77
    St. Petersburg, FL
    You can switch the nav from map mode to compass mode as well.
  6. CarlK
    CarlK New Member
    30
    North Carolina
    I think both Wal-Mart and K-mart sell a little gadget that fits over the corner of the mirror that mimics the electronic compass that isn't included on the Prius. I don't remember what it cost, but it wasn't exhorbitant.
    Carl
  7. billyb
    billyb New Member
    43
    Mirror Compass
    Thanks Carl
    I'll Check it out
    Billyb :D
  8. billyb
    billyb New Member
    43
    What's strange is that Toyota'S Prius Accessary lit.shows the Dimming rear view Mirror with a compass !!
  9. Tempus
    Tempus Senior Member
    1,690
    Washington DC
    The After Market Mirror is apparently different from the one that comes standard on the #9.
  10. HTMLSpinnr
    HTMLSpinnr Super Moderator
    5,341
    920
    251
    Surprise, AZ (Phoenix)
    Or the picture is simply incorrect?
  11. Tempus
    1,690
    Washington DC
    The After Market - (Non #9) Mirror has the following text.
    Improve your driving comfort with an Auto-dimming Mirror, built-in sensors detect headlight glare and automatically dim the mirror to reduce eyestrain. The digital compass provides directional information at your fingertips. Outside temperature feature is available on certain models. See a Toyota Parts Professional for more information.
    http://www.toyota.com/prius/accessories.html
    I suspect if it was wrong they'd correct it eventually, hehe.
    Since the #9 already has a compass and temperature readout, they probably saved a bit by not putting that redundant mirror on.
    Besides, if the Mirror and the MFD disagreed on something, people would keep bringing it back for service. People are funny that way.
    Better to have one display even if it's wrong.
  12. finman
    finman Senior Member
    1,287
    111
    Albany, OR
    2014 Nissan LEAF
    I've just recently replaced my standard mirror (non-homelink, non-autodim) with a compass/autodim mirror from an 03 Camry! I got it from ebay for $76 and it works great. I used the installation instructions for the Homelink mirror to find power (ACC) and ground. http://www.vfaq.net/mods/ECMirror.html. Looks great, works perfect. Just ever-so-slightly longer than the standard mirror, yet no sun visor issues. Took me under an hour. I'll try to post some pics later. Any other questions just ask. This is the third accessory I've installed myself (mudflaps and oil drain valve). Drive fun, drive clean, drive Prius!
  13. TonyPSchaefer
    14,816
    2,499
    66
    Far-North Chicagoland
    aforkosh mentioned that the temperature screen shows the outside temp. My wife's Buick Regal does the same time. But from time to time I want to know what the internal temperature is. The way I see it, there much be a thermostat that the A/C system is using to analyse the internal temp. Does it display?
