Opinions on this tire tread?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Mendel Leisk, Mar 17, 2015.
  1. frodoz737
    frodoz737 Top Wrench
    4,694
    2,495
    33
  2. Okinawa
    Okinawa Senior Member
    1,333
    320
    Just my opinion. I would buy new tires. When I go on a trip or drive at highway speeds I don't want to even have to think about my tires.
  3. Former Member 68813
    3,524
    983
    US
    based on what the OP explained, the tire is OK and should be usable to 8 years, after that there is increased risk. what is the speed rating of this tire?
  4. wjtracy
    wjtracy Senior Member
    11,366
    3,608
    Northern VA (NoVA)
    I had some GY Comfortreds on the rear about 90000 miles and maybe it was 5.5 yrs. Tread looked OK but day before I was scheduled to put on new Tire Rack tires was rainy and my wife spun out with a little fender bender. I'd have felt better if I'd had the new tires on there.
  5. CR94
    CR94 Senior Member
    2,692
    1,173
    Northwestern S.C.
    Probably not a problem if it has been stable for over a year and if you can't see anything but rubber looking into it in good lighting. I'd watch to make sure it doesn't start growing.
  6. Mendel Leisk
    41,397
    Here's the tirerack info, think there's only one rating:
    Michelin Pilot HX MXM4
  7. Former Member 68813
    3,524
    983
    US
    i looked it up. it's V-rated, excellent. the NHTSA study on tread separation showed that the tire aging problem was mostly limited to south USA (=high temps), low speed rating (=low quality), and some brands (again, low quality).
  8. frodoz737
    4,694
    2,495
    33
    That goes to the carcass. Out of limits.
