Has Toyota's Styling Gone Too Far?
Discussion in 'Prius, Hybrid, EV and Alt-Fuel News' started by cyclopathic, Mar 2, 2015.
  1. bisco
    51,541
    just looked inside an ls460 or whatever they are these days. 2 upholders in all that massive real estate between the driver and passenger seat?:confused: not impressed with lexus styling. even hyundai and kia are starting to look better. fortunately for toyota, they have a lot of other things going for them. specifically, function over form.
  2. Mendel Leisk
    40,990
    Once upon a time there were bumpers on the front. That's old-hat now I guess. :(
    Silver bullit likes this.
  3. Sergiospl
    Sergiospl Senior Member
    3,938
    1,351
    28
    Toyota is ahead right now, but the others are coming! :)
  4. Tideland Prius
    16,504
    I wanna know how much of a pain in the butt it is to clean the F-Sport honeycomb grilles after a bug-infested summer drive.
    GrumpyCabbie likes this.
  5. Mendel Leisk
    40,990
    Or how to grill block.
  6. bisco
    51,541
    will that attract bees?
  7. Tideland Prius
    16,504
    Just hope Toyota invests in active grille shutters
    TonyPSchaefer and retired4999 like this.
  8. hill
    8,726
    It'll take a big motor to close down that much grillwork real estate.
  9. GrumpyCabbie
    GrumpyCabbie Senior Member
    6,722
    2,121
    45
    North Yorkshire, UK
    Or a rabbit. Having wiped out a my fair share of road kill (accidentally of course), I'm a fan of hard bumpers. I can see those new grills getting wiped out by some animal with no road sense as well as those who park with their bumpers.
  10. sdtundra
    sdtundra Senior Member
    1,314
    193
    Sacramento, CA
    Still looks good to this day, as well as the LS430 being a runner up. I don't like how they went with the S-class look on the LS460.
    Tideland Prius likes this.
  11. GrumpyCabbie
    6,722
    2,121
    45
    North Yorkshire, UK
    Lexus obviously spent a lot of time designing that right, and then seem to have rushed their later models to the point where they're anonymous. The same happened with Mazda and their Eunos/MX5 Roadster. The original was perfect, and then slowly got fat and dull thereafter. I think Toyota have done the same with the Prius. The gen2 was well designed and the gen3 whilst modern, just doesn't have that certain je ne sais quoi. (and I own one)
    Rae Vynn likes this.
  12. CR94
    CR94 Senior Member
    2,676
    1,159
    Northwestern S.C.
    We still have bumpers on the front now, but too often disguised as the middle section of outsized, partially-fake grills.
    Stupid-large black plastic grills are just as ridiculous now as stupid-large chromy metal ones were circa 1950. See current-generation Focus for a less expensive example of this silliness. Grills should be only large enough to admit adequate cooling air, and as inconspicous as possible. The 2nd- and 3rd-generation Prii have a nicer noses than most of the stuff shown in this thread! (So does a '76 Vega, for that matter.)
  13. Mendel Leisk
    40,990
    Yeah, now that's a bumper. ;)
    And I'd expect it mounted to hydraulically damped stong points.
    I know, with today's cars everything for'ard of the fire wall is crumple zone, pretty much a write-off in a front ender.
    #33 Mendel Leisk, Mar 19, 2015
  14. El Dobro
    El Dobro A Member
    7,079
    3,259
    I used to have a '75 Cosworth Vega, #1131.
  15. Tideland Prius
    16,504
    It's not all open. The actual opening is much smaller than the grille design.
  16. Trollbait
    12,438
    Yes, cause the designers know that no engine really needs that much air flow. Heck, the top grill on the Sonic isn't even all open.
  17. bwilson4web
    16,124
    There is an aerodynamic trick that involves generating small vortexes that 'adhere' to the surface. However, this is done just before where flow-separation would occur, near the back, not at the front. No, this is just ugly.
  18. Tideland Prius
    16,504
    It's the current trend. You can thank Audi for that.
  19. SageBrush
    SageBrush Senior Member
    11,627
    2,533
    Southwest Colorado
    Rhetorical Titles are Annoying
  20. Trollbait
    12,438
    Not disagreeing with these cars, but vortex generators can help near the front, if underneath. AN old article once tested the use of AirTabs on the first gen Prius and Insight. No MPG results, just basic string testing on the back window, but they did try slabbing 4 or so Tabs under the Insight before the engine bay. Nothing quantitative, but reported it stablized the Insight's squirrelliness at speed. With an ICE, a completely flat belly sheet isn't possible, so there will be some dirty flow.
