2008 light switch - how to replace light switch
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by aprius, Mar 20, 2015.
  1. aprius
    aprius Junior Member
    26
    I
    Hello all. I was wondering in anyone can assist me in how to replace the "light switch" on an 08 Prius. The driver side headlight and taillight will come on when you first turn on the lights and but will turn off in just a few seconds. Sometimes they will stay on for a while and/or go off and on. I was told it was the "light switch".
    Any suggestions or how to replace that would be very appreciated.
    Thanks
  2. nh7o
    nh7o Off grid since 1980
    1,686
    340
    Hawaii
    What type of headlights do you have? HID?
    Are you saying that the front and rear lights go off and on at exactly the same time? In unison?
    The passenger side lights work normally all the time?
    How old is the 12V battery? Original equipment?
  3. aprius
    26
    I
    HID Yes
    Yes both front and tail lights will go and on in unison and stay off once they go off
    Passenger lights stay on as normal and are not an issue at all
    Brand new battery
    Small driving lights work on both sides
    All turn signals and parking lights still work on both sides
    Yes it is weird :)
  4. Easy Rider 2
    Easy Rider 2 Senior Member
    1,584
    258
    Ocala, FL
    I suggest that you need to test the switch before actually replacing it; might save a good bit of money.
    There likely is a bad connection that goes open when it heats up; might be in the switch, might be somewhere else.
  5. nh7o
    1,686
    340
    Hawaii
    From the circuit diagram, one can safely conclude that the problem is not with the light switch (i.e. on the end of the stalk) as there is no separation of left and right side wiring at that point. The rear lights have no individual left-right wiring at all, i.e. they are in parallel. The head lights and tail lights are on separate fuses. There are separate left and right fuses for the head lights, but those have no connection to the rears.
    Note that the license plate light is powered by the RH (passenger side) tail light, so check that for another clue.
    We have seen plenty of intermittent head lights over the years, and a smattering of intermittent tail lights. The former are generally due to the need for bulb replacement. They can sometimes be encouraged to stay on for a while by switching them on and off until they start. The tail light problems can be due to the need for a replacement LED, or due to a corroded ground connection which can be found under the liftback latch, interior side.
    Another area that could tie these two together is poor connections to your new battery, which can cause voltage fluctuations that might interfere with HIDs coming on. Check the bolt to the chassis for tightness. Make sure the battery is well charged.
    There is nothing for it but to get out a DVM and start checking voltages. Start with the tail lights and see if there is voltage to the plug. I think there are two problems, and the fact that they are happening together is mostly fortuitous.
    #5 nh7o, Mar 21, 2015
  6. Easy Rider 2
    1,584
    258
    Ocala, FL
    Nice theory. But I wouldn't call two different problems ALWAYS manifesting themselves at the same time "fortuitous".
    I think that is unlikely unless the two problems have a common factor.
  7. Longinus876
    Longinus876 Member
    105
    Long Island
    I need to check/clean the contacts on the headlight/signal stalk. Halogen headlight on the rt side will not go to brights. If I flash the brights, it momentarily goes on.(split second) I can't get at the contacts on that stalk and would like some guidance. It's an '05 Prius. I don't see a way of opening unit to clean the contacts.
  8. mr_guy_mann
    mr_guy_mann Senior Member
    4,080
    1,994
    NJ-USA
    If the left side headlight functions correctly, then the light and high beam switch must be working correctly. The two sides split apart downstream of the switch.
    Brian1954 likes this.
